What would be the best way to check 0.35 cylindricity inside plastic tube, 240 mm length, wall thickness 1.5 mm, inside diameter 35 mm? I only have touch trigger scanning capability. I don't think I can build 10 inches long probe and get accurate results.
Best way to check cylindricity?
Originally posted by Schrocknroll View PostIf the tube is open on both ends then you only need a 5" long probe, still your accuracy will be an issue. You will want to build it with carbon fiber or ceramic extensions and an extended force module to keep it from false triggers.Last edited by marcc; 08-28-2019, 10:52 AM.
Originally posted by JacobCheverie View PostThe TP2 can be extended over 11", you have to watch the accuracy and weight though. Some light weight extensions should be okay. You can always run it slow to prevent false triggers and you can flip the part halfway through the program to measure the entire tube.
Originally posted by marcc View Post
I only have TP2, no option for extended force module. Also tube is fully open from one end, the other end has only 21 mm diameter opening.PC-DMIS 2016.0 SP8
Jeff
by jay RGood morning,
Using a medium force puck for my my tp200, how long and how big of a stylus can I build?
I am shooting for a 5...-
05-06-2009, 10:48 AM -
by DaddyBlutoI am trying to get believable results using a crazy long probe due to my part configuration. The probe is 30mm steel extension into a 90mm carbon fiber...
07-02-2018, 04:14 PM -
by Ken8282I currently have all my probe with stainless steel stems. I need to purchase a 6 mm by 50 probe but am only seeing one with a carbon fiber stem. Is there...
08-18-2015, 08:37 AM -
by B. JacobsI am sure someone knows this answer and could help me out.
I would like to know what is the maxium extension length I could use for the modules...-
11-01-2006, 03:10 PM -
by keegoI did search the forum but no help. I'm trying for the first time to calibrate a 0.5 mm stylus. It keeps coming up diameter out of tolerance because...
07-21-2010, 03:29 PM -
