Not sure why CMM stops in the middle of the program while the probe inside a hole without any messages or errors. any ideas what is going on here?
many thank is
Tamer
many thank is
Tamer
CLEARP/ZPLUS,PLN_TOP.Z+0.25,ZPLUS,PLN_TOP.Z+0.25,ON MOVE/POINT,NORMAL,<0,0,PLN_TOP.Z+1> TIP/T1A-95B0, SHANKIJK=0, -0.9962, -0.0872, ANGLE=0 CLEARP/YMINUS,-1.75,ZMINUS,-3.4,ON MOVE/POINT,NORMAL,<0,-1.75,1> MOVE/CLEARPLANE RAD_G_1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-3.4>,<0,0,1>,2.4027,0 ACTL/<0,0,-3.4>,<0,0,1>,2.4027,0 TARG/<0,0,-3.4>,<0,0,1> START ANG=182.5,END ANG=-2.5 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO RAD_G_2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-4.075>,<0,0,1>,2.4027,0 ACTL/<0,0,-4.075>,<0,0,1>,2.4027,0 TARG/<0,0,-4.075>,<0,0,1> START ANG=-2.5,END ANG=182.5 ANGLE VEC=<1,0,0> DIRECTION=CW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO RAD_G_3 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-4.75>,<0,0,1>,2.4027,0 ACTL/<0,0,-4.75>,<0,0,1>,2.4027,0 TARG/<0,0,-4.75>,<0,0,1> START ANG=182.5,END ANG=-2.5 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO MOVE/INCREMENT,<0.25,0,0> RAD_H_1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-7.45>,<0,0,1>,2.3781,0 ACTL/<0,0,-7.45>,<0,0,1>,2.3781,0 TARG/<0,0,-7.45>,<0,0,1> START ANG=-2.5,END ANG=182.5 ANGLE VEC=<1,0,0> DIRECTION=CW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO RAD_H_2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-7.66>,<0,0,1>,2.3781,0 ACTL/<0,0,-7.66>,<0,0,1>,2.3781,0 TARG/<0,0,-7.66>,<0,0,1> START ANG=182.5,END ANG=-2.5 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO MOVE/POINT,NORMAL,<1.425,-0.55,-7.66> MOVE/POINT,NORMAL,<1.425,-0.55,2> TIP/T1A-95B180, SHANKIJK=0, 0.9962, -0.0872, ANGLE=0 CLEARP/YPLUS,1.75,ZMINUS,-3.4,ON MOVE/POINT,NORMAL,<0,1.75,1> MOVE/CLEARPLANE RAD_G_4 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-3.4>,<0,0,1>,2.4027,0 ACTL/<0,0,-3.4>,<0,0,1>,2.4027,0 TARG/<0,0,-3.4>,<0,0,1> START ANG=177.5,END ANG=362.5 ANGLE VEC=<1,0,0> DIRECTION=CW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO RAD_G_5 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-4.075>,<0,0,1>,2.4027,0 ACTL/<0,0,-4.075>,<0,0,1>,2.4027,0 TARG/<0,0,-4.075>,<0,0,1> START ANG=2.5,END ANG=-182.5 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO RAD_G_6 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-4.75>,<0,0,1>,2.4027,0 ACTL/<0,0,-4.75>,<0,0,1>,2.4027,0 TARG/<0,0,-4.75>,<0,0,1> START ANG=177.5,END ANG=362.5 ANGLE VEC=<1,0,0> DIRECTION=CW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO MOVE/INCREMENT,<0.25,0,0> RAD_H_3 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-7.45>,<0,0,1>,2.3781,0 ACTL/<0,0,-7.45>,<0,0,1>,2.3781,0 TARG/<0,0,-7.45>,<0,0,1> START ANG=2.5,END ANG=-182.5 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO RAD_H_4 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-7.66>,<0,0,1>,2.3781,0 ACTL/<0,0,-7.66>,<0,0,1>,2.3781,0 TARG/<0,0,-7.66>,<0,0,1> START ANG=177.5,END ANG=362.5 ANGLE VEC=<1,0,0> DIRECTION=CW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO SCN1 =FEAT/SET,CARTESIAN THEO/<0,0,-3.4>,<0,0,1> ACTL/<0,0,-3.4>,<0,0,1> CONSTR/SET,BASIC,RAD_G_1.hit[1..5],RAD_G_4.hit[1..5],, CIR_G1 =FEAT/CIRCLE,CARTESIAN,OUT,LEAST_SQR,NO THEO/<0,0,-3.4>,<0,0,1>,2.4027 ACTL/<0,0,-3.4>,<0,0,1>,2.4027 CONSTR/CIRCLE,BF,2D,SCN1,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 PNT_G1 =FEAT/POINT,CARTESIAN,NO THEO/<0,0,-3.4>,<0,0,1> ACTL/<0,0,-3.4>,<0,0,1> CONSTR/POINT,CAST,CIR_G1 SCN4 =FEAT/SET,CARTESIAN THEO/<0,0,-4.075>,<0,0,1> ACTL/<0,0,-4.075>,<0,0,1> CONSTR/SET,BASIC,RAD_G_2.hit[1..5],RAD_G_5.hit[1..5],, CIR_G2 =FEAT/CIRCLE,CARTESIAN,OUT,LEAST_SQR,NO THEO/<0,0,-4.075>,<0,0,1>,2.4027 ACTL/<0,0,-4.075>,<0,0,1>,2.4027 CONSTR/CIRCLE,BF,2D,SCN4,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 PNT_G2 =FEAT/POINT,CARTESIAN,NO THEO/<0,0,-4.075>,<0,0,1> ACTL/<0,0,-4.075>,<0,0,1> CONSTR/POINT,CAST,CIR_G2 SCN7 =FEAT/SET,CARTESIAN THEO/<0,0,-4.75>,<0,0,1> ACTL/<0,0,-4.75>,<0,0,1> CONSTR/SET,BASIC,RAD_G_3.hit[1..5],RAD_G_6.hit[1..5],, CIR_G3 =FEAT/CIRCLE,CARTESIAN,OUT,LEAST_SQR,NO THEO/<0,0,-4.75>,<0,0,1>,2.4027 ACTL/<0,0,-4.75>,<0,0,1>,2.4027 CONSTR/CIRCLE,BF,2D,SCN7,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 PNT_G3 =FEAT/POINT,CARTESIAN,NO THEO/<0,0,-4.75>,<0,0,1> ACTL/<0,0,-4.75>,<0,0,1> CONSTR/POINT,CAST,CIR_G3 SCN10 =FEAT/SET,CARTESIAN THEO/<0,0,-7.66>,<0,0,1> ACTL/<0,0,-7.66>,<0,0,1> CONSTR/SET,BASIC,RAD_H_2,RAD_H_4,, CIR_H2 =FEAT/CIRCLE,CARTESIAN,OUT,LEAST_SQR,NO THEO/<0,0,-7.66>,<0,0,1>,2.3781 ACTL/<0,0,-7.66>,<0,0,1>,2.3781 CONSTR/CIRCLE,BF,2D,SCN10,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 PNT_H2 =FEAT/POINT,CARTESIAN,NO THEO/<0,0,-7.66>,<0,0,1> ACTL/<0,0,-7.66>,<0,0,1> CONSTR/POINT,CAST,CIR_H2 SCN13 =FEAT/SET,CARTESIAN THEO/<0,0,-7.45>,<0,0,1> ACTL/<0,0,-7.45>,<0,0,1> CONSTR/SET,BASIC,RAD_H_1.hit[1..5],RAD_H_3.hit[1..5],, CIR_H1 =FEAT/CIRCLE,CARTESIAN,OUT,LEAST_SQR,NO THEO/<0,0,-7.45>,<0,0,1>,2.3781 ACTL/<0,0,-7.45>,<0,0,1>,2.3781 CONSTR/CIRCLE,BF,2D,SCN13,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 PNT_H1 =FEAT/POINT,CARTESIAN,NO THEO/<0,0,-7.45>,<0,0,1> ACTL/<0,0,-7.45>,<0,0,1> CONSTR/POINT,CAST,CIR_H1 WORKPLANE/YMINUS LIN_GH =FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0,0,-3.4>,<0,0,-1> ACTL/<0,0,-3.4>,<0,0,-1> CONSTR/LINE,BF,3D,PNT_G1,PNT_G2,PNT_G3,PNT_H1,PNT_H2,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 WORKPLANE/ZPLUS A3 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZMINUS,LIN_GH ALIGNMENT/TRANS,XAXIS,LIN_GH ALIGNMENT/TRANS,YAXIS,LIN_GH ALIGNMENT/TRANS,ZAXIS,PLN_TOP ALIGNMENT/END WORKPLANE/YPLUS LIN_YP =FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0,-0.5,0>,<0,1,0> ACTL/<0,-0.5,0>,<0,1,0> CONSTR/LINE,ALIGN,1,WORKPLANE WORKPLANE/ZPLUS A4 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZMINUS,LIN_GH ALIGNMENT/ROTATE,YPLUS,TO,LIN_YP,ABOUT,ZMINUS ALIGNMENT/TRANS,XAXIS,LIN_GH ALIGNMENT/TRANS,YAXIS,LIN_GH ALIGNMENT/TRANS,ZAXIS,PLN_TOP ALIGNMENT/END
