Projecting a base circle over two lines
  • Projecting a base circle over two lines
    I attached a screen shot for reference. Not easy to explain so hopefully that helps. I need to create intersection points between LIN1/LIN2 and a virtual circle centered at 0,0 with a diameter of 6.8. From there I can measure the distance between points to determine if the lines are the correct distance apart. Any advice? F3 was an attempt at generic cylinder but the lines wont intersect properly. Annotation 2019-08-26 164527.png
    the picture is blurry, are those lines parallel? I'm thinking they must not be or you could just use a constructed width to measure between them
      The lines are not parallel. They make an 8 degree angle.
        You need to create “pierce” points AND you might have to create “reverse” lines of LIN1 and LIN2 to pierce the circle at the correct point.
