Hey folks,
I'd recently asked about setting up a part to run based on a readpoint or one point touch off.
I'm already familiar with the fact that it has to be squared up evenly, and I've got this working pretty well for the most part, but I've found another wrench in the gears with some of my parts.
If the Datums are lined up nice and neat on the X Y and Z axis, merely using Part setup in the Setup Options menu (F5) to tell it how the part is sitting on the CMM works fine.
Similarly, if I had any surface, features, or edge to line up along an axis, I could line those up somehow, but I've already had a few parts that don't play nice.
Is there a way I can tell PC DMIS to orient features along a machine axis after starting with a Readpoint, before I've actually measured anything, so when it moves from the readpoint, it can correctly get to each feature needed for the DCC alignment?
An example of what I've found is Datum B and Datum C are similar to the Before picture according to the CAD model and it's axes, but I've got the part set up like the After picture on the CMM, because it's the best way to orient and secure the part on the plate.
I know I can determine the nominal angle to any of the axes by plotting a line between datum B and C and checking its angle. I assume there's a way to offset this angle to instruct PC DMIS on where the part sits compared to the machine axis.
Thanks in advance, you guys are incredibly helpful!
