How to program with wrist angles
  • How to program with wrist angles
    I am struggling to get the correct dimensioning to match the callouts on my blueprint and am wondering if there is an issue with how I"ve programmed the wrist angles or if the issue is my alignment.
    GRP1 =GROUP/SHOWALLPARAMS=YES
    PLN1 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
    THEO/<1.3954,-0.4458,0.915>,<0,0,1>
    ACTL/<6.71,0.6603,-11.7681>,<-0.0011253,-0.0073911,0.9999721>
    TARG/<1.3954,-0.4458,0.915>,<0,0,1>
    ANGLE VEC=<1,0,0>,SQUARE
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=YES
    NUMHITS=2,NUMROWS=2
    SPACER=0
    AVOIDANCE MOVE=BOTH,DISTANCE=0.3937
    SHOW HITS=NO
    PLN2 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
    THEO/<0.0709,-0.845,0.6538>,<0,-1,0>
    ACTL/<6.7092,-0.1544,-12.1243>,<-0.0006784,-0.9999684,-0.0079156>
    TARG/<0.0709,-0.845,0.6538>,<0,-1,0>
    NUMHITS=2,NUMROWS=2
    SPACER=0
    SHOW HITS=NO
    TIP/T1A90B90, SHANKIJK=-1, 0, 0, ANGLE=90
    PLN3 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
    THEO/<0,-0.1216,0.7307>,<-1,0,0>
    ACTL/<5.4302,0.6742,-12.6831>,<-0.9999989,0.0006619,-0.0013132>
    TARG/<0,-0.1216,0.7307>,<-1,0,0>
    ANGLE VEC=<0,0,1>,SQUARE
    NUMHITS=2,NUMROWS=2
    SPACER=0
    SHOW HITS=NO
    ALIGNMENT/LEVEL,ZPLUS,PLN1
    ALIGNMENT/TRANS,ZAXIS,PLN1
    ALIGNMENT/ROTATE,YMINUS,TO,PLN2,ABOUT,ZPLUS
    ALIGNMENT/TRANS,YAXIS,PLN2
    ALIGNMENT/TRANS,XAXIS,PLN3
    ALIGNMENT/END
    CIR1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<0,0.845,-0.915>,<-1,0,0>,1.3185
    ACTL/<0,0.8351,-0.9239>,<-1,0,0>,1.3025
    TARG/<0,0.845,-0.915>,<-1,0,0>
    START ANG=0,END ANG=360
    ANGLE VEC=<0,0,1>
    DIRECTION=CCW
    NUMHITS=4,DEPTH=0.0968,PITCH=0
    SAMPLE METHOD=SAMPLE_HITS
    SAMPLE HITS=0,SPACER=0
    AVOIDANCE MOVE=NO,DISTANCE=0.3937
    SHOW HITS=NO
    TIP/T1A0B0, SHANKIJK=0.0011, 0.0074, 1, ANGLE=0.0389
    ALIGNMENT/TRANS,YAXIS,CIR1
    ALIGNMENT/TRANS,ZAXIS,CIR1
    ALIGNMENT/END
    ENDGROUP/ID=GRP1
    MODE/DCC
    GRP2 =GROUP/SHOWALLPARAMS=YES
    PLN4 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
    THEO/<1.5245,-0.3686,0.915>,<0,0,1>
    ACTL/<1.5245,-0.3686,0.9239>,<-0.0000154,-0.000016,1>
    TARG/<1.5245,-0.3686,0.915>,<0,0,1>
    NUMHITS=3,NUMROWS=3
    SPACER=0
    USE BOUNDARY OFFSET=YES,OFFSET=50.7999
    SHOW HITS=NO
    PLN5 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
    THEO/<1.4266,-0.845,-0.1161>,<0,-1,0>
    ACTL/<1.4266,-0.8349,-0.1161>,<0.0000033,-1,-0.0001718>
    TARG/<1.4266,-0.845,-0.1161>,<0,-1,0>
    NUMHITS=3,NUMROWS=2
    SPACER=0
    SHOW HITS=NO
    TIP/T1A90B90, SHANKIJK=-1, -0.0007, 0.0011, ANGLE=90.4235
    PLN6 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
    THEO/<0,-0.7732,0.39>,<-1,0,0>
    ACTL/<0.0002,-0.7732,0.39>,<-1,0.0000728,-0.0001476>
    TARG/<0,-0.7732,0.39>,<-1,0,0>
    NUMHITS=3,NUMROWS=3
    SPACER=0
    SHOW HITS=NO
    A3 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
    ALIGNMENT/LEVEL,ZPLUS,PLN4
    ALIGNMENT/TRANS,ZAXIS,PLN4
    ALIGNMENT/ROTATE,YMINUS,TO,PLN5,ABOUT,ZPLUS
    ALIGNMENT/TRANS,YAXIS,PLN5
    ALIGNMENT/TRANS,XAXIS,PLN6
    ALIGNMENT/END
    CIR2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    ACTL/<0,0.8351,-0.9239>,<-1,0,0>,1.3024
    ANGLE VEC=<0,0,1>
    DIRECTION=CCW
    NUMHITS=10,DEPTH=0.0787,PITCH=0
    SHOW HITS=NO
    A4 =ALIGNMENT/START,RECALL:A3,LIST=YES
    ALIGNMENT/TRANS,YAXIS,CIR2
    ALIGNMENT/TRANS,ZAXIS,CIR2
    ALIGNMENT/END
    ENDGROUP/ID=GRP2
    GRP3 =GROUP/SHOWALLPARAMS=YES
    CIR13 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<0,-0.625,-0.6875>,<-1,0,0>,0.272
    ACTL/<0,-0.6249,-0.6876>,<-1,0,0>,0.2689
    TARG/<0,-0.625,-0.6875>,<-1,0,0>
    ANGLE VEC=<0,0,1>
    DIRECTION=CCW
    SHOW HITS=NO
    Wrist angles should have nothing to do with your measurements. As long as its a calibrated angle, and you are making good ruby contact and not "shanking" , angle has nothing to do with it.
      Step 1: Don't assume that the root cause(s) of the problem is the first thing your brain comes up with.
      Step 2: Don't make two threads about same subject.
      Step 3: See other thread.
      • sscandlon
        sscandlon commented
        This is not the same subject I meant to delete the other thread because I realized what I was doing wrong and the other thread your referring to just says to post the code which I can do here as well . I'm just simply asking for some guidance .
