Update 8/21/19:
I still have the issue. Hex remoted into my computer yesterday. Here's what happened-->
1) Since 2019R1 still works for me.. went into 2019R1 Settings Editor, saved those settings, then sucked those settings into Settings Editor for 2019R2. We then re-opened 2019R2 and the issue was still there. Tech then restored my original settings since this didn't fix it.
2) Went into my C/ drive and deleted the GBRSTAT (whatever the heck that is..I have no idea..), deleted the file that controls my saved window layouts, as well as deleted the file that controls my custom toolbars. We then reopened 2019 R2 and the issue was still there.
3) Tech was able to confirm that there isn't a graphic window switch that we're all missing..there is no "radial probe compensation" toggle for the graphics display window
4) Tech made note of the fact that I made this post on the forum and that michaelwildschutz was able to duplicate my issue.
5) Tech said this definitely looks like a graphics bug. Said they're going to send this to the developers and hopefully this can be addressed in the next service pack.
__________________________________________________ __________________________________________________ ___________________________________
All,
Description of issue-->
Using 2019 R2...
After I Import a stp file, every time I click on a surface and try to make an autofeature...the probe is being visibly sucked into the model by exactly the radial value of the ball.
For example:
Green surface is X0 with the correct vector..but as you can see the probe doesn't look right. My prehit & retract are set to 0.0001 for programming purposes and I have verified that there are no depth, avoidance, sample, or void moves messing me up...and I'm still into my model on my screen. =(
If I open the same program that looks messed up but in 2019 R1, everything works & looks fine. If I run the 2019R2 program online on the CMM, everything RUNS fine but the probe still looks burried in the model on the screen.
Question-->
Is there a "add/subtract ball radius" setting or something for the graphic display window setting that I can't find & never knew existed?? Or is this a bug? Anyone else seeing this?
All,
Using 2019 R2...
For example:
Question-->
