PCDMIS 2019 XSTATS11.TMP file
  • PCDMIS 2019 XSTATS11.TMP file
    Does 2019 output a XSTATS11.tmp file once you've selected Datapage output? It seems that it outputs a .tmp file but instead of appending the data, it makes a new .tmp file for each run so you have multiple files instead of 1 appended file.
    do not completely understand your question. What are the names of the new tmp files there should only be 1 XSTATS11.TMP file.
    Using v2019R1 I added a STATS for datapage. Ran it multiple times indicating Yes to save stats and NO to update now.
    At the end I had multiple runs in the single XSTATS11.TMP file found under
    C:\ProgramData\Hexagon\PC-DMIS\2019 R1
      Here are some snapshots of what I have done...I don't see where I can actually select "Yes to save stats..." as you stated above.
        when you execute pcdmis will ask if you want to save stats (unless you have set a default selection for that dialog question) F5 / Dimensions (Always save stats to file)
        when execution is complete pcdmis will ask you if you want to update the database now (unless you have set a default selection for that dialog question) F5 / Dimensions (Always update database).
          Here is what I get following your instructions..no file named "xstats11.tmp"
          • SABarber
            SABarber commented
            " It seems that it outputs a .tmp file but instead of appending the data, it makes a new .tmp file for each run so you have multiple files instead of 1 appended file."
            I do not understand the original question then. Somewhere there seems to be multiple files.
