https://drive.google.com/file/d/1BBh...ew?usp=sharing
the bore on the right is what I am trying to measure but each time the machine crashes into the flat face of the part instead of measuring the circle
this is the program alignment manual and DCC as well as the feature I am trying to measure:
GRP1 =GROUP/SHOWALLPARAMS=YES
PLN1 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
THEO/<1.6164,-0.5238,0.915>,<0,0,1>
ACTL/<6.7258,0.6721,-11.7697>,<-0.0002715,-0.0062496,0.9999804>
TARG/<1.6164,-0.5238,0.915>,<0,0,1>
ANGLE VEC=<1,0,0>,SQUARE
SHOW FEATURE PARAMETERS=NO
SHOW CONTACT PARAMETERS=YES
NUMHITS=2,NUMROWS=2
SPACER=0
AVOIDANCE MOVE=NO,DISTANCE=0.3937
SHOW HITS=NO
PLN2 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
THEO/<0.6746,-0.845,0.526>,<0,-1,0>
ACTL/<6.6972,-0.1546,-12.1153>,<-0.0007103,-0.9999759,-0.0068996>
TARG/<0.6746,-0.845,0.526>,<0,-1,0>
NUMHITS=2,NUMROWS=2
SPACER=0
SHOW HITS=NO
TIP/T1A90B90, SHANKIJK=-1, 0, 0, ANGLE=90
PLN3 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
THEO/<0,-0.1395,0.7148>,<-1,0,0>
ACTL/<5.4142,0.669,-12.688>,<-0.9999994,0.0010129,-0.000434>
TARG/<0,-0.1395,0.7148>,<-1,0,0>
ANGLE VEC=<0,0,1>,SQUARE
NUMHITS=2,NUMROWS=2
SPACER=0
SHOW HITS=NO
ALIGNMENT/LEVEL,ZPLUS,PLN1
ALIGNMENT/TRANS,ZAXIS,PLN1
ALIGNMENT/ROTATE,YMINUS,TO,PLN2,ABOUT,ZPLUS
ALIGNMENT/TRANS,YAXIS,PLN2
ALIGNMENT/TRANS,XAXIS,PLN3
ALIGNMENT/END
ENDGROUP/ID=GRP1
MODE/DCC
GRP2 =GROUP/SHOWALLPARAMS=YES
TIP/T1A0B0, SHANKIJK=0.0003, 0.0062, 1, ANGLE=0.0407
PLN4 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
THEO/<1.139,0.3462,0>,<0,0,1>
ACTL/<1.139,0.3462,-0.0002>,<-0.0000117,0.0000009,1>
TARG/<1.139,0.3462,0>,<0,0,1>
NUMHITS=2,NUMROWS=2
SPACER=0
SHOW HITS=NO
PLN5 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
THEO/<0.8722,0,-0.852>,<0,-1,0>
ACTL/<0.8722,0.0002,-0.852>,<0.0000021,-0.9999999,-0.000431>
TARG/<0.8722,0,-0.852>,<0,-1,0>
NUMHITS=2,NUMROWS=2
SPACER=0
SHOW HITS=NO
TIP/T1A90B90, SHANKIJK=-1, -0.0007, 0.0003, ANGLE=90.3581
PLN6 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
THEO/<0,0.2244,-1.3412>,<-1,0,0>
ACTL/<0.0002,0.2244,-1.3412>,<-1,0.0000577,-0.0001992>
TARG/<0,0.2244,-1.3412>,<-1,0,0>
NUMHITS=2,NUMROWS=2
SPACER=0
USE BOUNDARY OFFSET=YES,OFFSET=50.7999
SHOW HITS=NO
A2 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
ALIGNMENT/LEVEL,ZPLUS,PLN4
ALIGNMENT/TRANS,ZAXIS,PLN4
ALIGNMENT/ROTATE,YMINUS,TO,PLN5,ABOUT,ZPLUS
ALIGNMENT/TRANS,YAXIS,PLN5
ALIGNMENT/TRANS,XAXIS,PLN6
ALIGNMENT/END
ENDGROUP/ID=GRP2
CIR10 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
THEO/<2.625,0.845,-0.915>,<1,0,0>,1.25,0
ACTL/<2.625,0.845,-0.915>,<1,0,0>,1.25,0
TARG/<2.625,0.845,-0.915>,<1,0,0>
START ANG=0,END ANG=360
ANGLE VEC=<0,0,-1>
DIRECTION=CCW
NUMHITS=4,DEPTH=0,PITCH=0
SAMPLE METHOD=SAMPLE_HITS
SAMPLE HITS=0,SPACER=0
AVOIDANCE MOVE=BOTH,DISTANCE=0.5937
SHOW HITS=NO
NUMHITS=2,NUMROWS=2
SPACER=0
SHOW HITS=NO
NUMHITS=2,NUMROWS=2
SPACER=0
SHOW HITS=NO
NUMHITS=2,NUMROWS=2
SPACER=0
SHOW HITS=NO
ALIGNMENT/END
ENDGROUP/ID=GRP1
MODE/DCC
NUMHITS=2,NUMROWS=2
SPACER=0
SHOW HITS=NO
NUMHITS=2,NUMROWS=2
SPACER=0
SHOW HITS=NO
NUMHITS=2,NUMROWS=2
SPACER=0
SHOW HITS=NO
ALIGNMENT/END
ENDGROUP/ID=GRP2
ANGLE VEC=<0,0,-1>
DIRECTION=CCW
SHOW HITS=NO
