PC-DMIS 2019 R1 SP4 released
  • PC-DMIS 2019 R1 SP4 released
    PCD-111793 - Modified the procedure to map laser probes with a third axis to increase accuracy.
    PCD-151040 - Improved the design to compute the actual on 2D auto features. We now project the measured feature to its nominal plane.
    PCD-158884 - Fixed a Datum reference frame error message so that it isn't hidden behind another window.
    PCD-160838 - Fixed an issue where a generic Circle command that referenced polar coordinates did not appear correctly in the Graphic Display window.
    PCD-161247 - Fixed an issue with marked parent and child mode commands in Thickness Scan and Thickness Gage.
    PCD-163762 - Fixed an issue where PC-DMIS disabled some toolbars when you selected the Cancel button in the Arm 2 Execution dialog box. This issue also caused PC-DMIS to stop working when you closed the application.
    PCD-165202 - Fixed an issue where the size of the inspection routine was increased when you modified the Pointcloud Colormap command.
    PCD-165522 - Fixed an issue where PC-DMIS stopped working when you tried to print a legacy Hyper report directly.
    PCD-165593 - Fixed an issue where PC-DMIS was not responding when you use a star tip.
    PCD-165693 - Fixed an issue with the Round Slot icon in the feature list.
    PCD-165719 - Fixed a tessellation issue that affected some planar surfaces.
    PCD-166088 - Fixed a tessellation issue that caused spheres to render incorrectly.
    PCD-166331 - Fixed an issue where the clearplane was drawn in an incorrect location.
    PCD-166498 - Fixed the move after a 4-axis scan to reflect changes in TS 1.5.
    PCD-167535 - Fixed an issue where a measurement routine that contained a Feature Control Frame (FCF) with many features took a long time to partially execute (Ctrl + E).
    PCD-167602 - Fixed an issue where PC-DMIS stopped responding when you selected a surface profile GD&T.
    PCD-168126 - Fixed an issue where the extended sheetmetal features were not written to the xstats11.tmp file.
    PCD-168840 - Fixed an issue where PC-DMIS stopped responding for a Vision 2D profile feature with a nominal form filter.
    PCD-169610 - Fixed the rotation of an indexing head in the I++ client.
    PCD-169660 - Fixed an issue where the lower-level matrix could not be created and the tool changer didn't work properly when new names for the X1 probe components were used from the probe.dat file.
    PCD-169969 - Fixed an issue where a CIR scan didn't work when the machine axes on Leitz machines were redefined.
    PCD-170387 - Fixed an issue where the I++ server wasn't able to detect indexing wrist angles when the client session started.
    PCD-170614 - Fixed a Q-DAS Configurator issue where GD&T text was translated.
    PCD-171670 - Fixed an issue where the rotary table rotation matrix was not applied to transform the laser probe stripes from sensor to machine co-ordinates.
    PCD-172007 - Fixed the I++ server command FindTool for indexing heads with angles different than zero.
    Changes were made to improve the user experience based on feedback collected from recent releases.
    Hexagon Manufacturing Intelligence’s online support centre, offering a range of services including access to our knowledge base, articles on tips & tricks, software downloads and much more.
    PC-DMIS CAD++ 2o23.1
    Originally posted by Wilcoxagon
    "Changes were made to improve the user experience based on feedback collected from recent releases. "
    Oh wow!
      ....PCD-168840 - Fixed an issue where PC-DMIS stopped responding for a Vision 2D profile feature with a nominal form filter.
      That is a start, but not sure the 2D profile patient is OK to get up from the hospital bed just quite yet:::::
        Hopefully it's actually fixed! I'll have to test this out.
