Checking for twist
  • Checking for twist
    I have a part that they are wanting to check for twist, the part measures 72.5" long. I need to find a repeatable way to fixture and check this part, without changing the free state characteristics of the part. Up for suggestion. We have a B&S with a TP-200.
    a square bolted to the table to 'datum' a corner, and a straight edge at the other end to stop rotation, push the part against the straight edge at one end and tuck it into the corner of the square.
    • merlin1968
      merlin1968 commented
      If I had access to a romer arm with scanning capabilities would that be better being non contact
    Before you even begin, nail down the format and units for the vague word "twist".
    Is there a print dimension, and is it expressed in inches/mm/decimal degrees/degrees-minutes-seconds/thumb-sized gaps? Is there a tolerance?
    If no print dimension, ask the people wanting the data what format they understand.
    • merlin1968
      1 degree per foot, max 7 degrees per full length
    You may need some kind of fixture to hold this thing ??? Really you need to check flatness and straightness of a line to come close to what you are looking for ? That looks like an extruded part we made at one time except in plastic ? Or is it an aluminum extrusion and just painted ?
