Can anyone clarify or define the difference between Level2 and Level3 measurement points?
Automotive Level2 vs. Level3 Measurement Points
Level 3 are used for SPC, Level 2 are 'full check'. Level 4 are usually data collector bushings on the fixture for 'at the press' data collection.
Level 2 includes all Level 3 and Level 4 points
Level 3 includes all Level 4 points
Level 4 points are all alone.sigpic
- Likes 1
Originally posted by jleond View PostNon mating surfaces, clearance or drain holes, basically all those features that are not critical for dimensional integrity of the part.sigpic
by qcfire65
I needed to measure a profile around the 67mm area in print. Print calls back to "C" and I took four points on C1 & C2 creating...-
02-19-2015, 08:39 AM -
by arthurfi26I have a Leica LTD 800 and I’m using PC-DMIS pro version 2011. I am trying to work out if a surface table is completely level. Do I have to have a known...
11-17-2011, 07:41 AM -
Okay Guys and Gals..I just finished programming a part using the iterative alignment for a part on a commercial airliner (some type of fairing ). It has...
03-03-2008, 12:49 PM -
by Mike_BLets say I have an L shaped piece of steel. 1/4" thick, 8" wide, 8" tall, and the bottom of the L is 4"
Thats just...-
08-04-2015, 10:46 AM -
by DHoyeGood morning all you 3rd Shifters!! I have a question..I know you have to level, rotate, and origin when you have an alignment.but what do you rotate...
03-23-2008, 11:51 PM -
