Is it possible to see the individual point data and the deviation from fit within features? (Auto or Probed Features) Example, an autocircle with 15 points, it creates a Least_SQR circle. Can I see what points deviate most from the fit? Can I deselect or eliminate some points and recalculate the circle? Then reapply the points to get back to the original?
Deviation from Fit - Individual Points
Insert -> Report command -> Pointinfo...
And no, you can't deselect hits. To do that, you need to collect the hits as separate Vector Points and construct the feature afterwards. Then you are free to ignore one (or more) of the hits. But why would you?Last edited by AndersI; 08-07-2019, 09:06 AM.AndersI
- 1 like
by Hugo_1522I would like to extract the hit points from a feature, like say a plane with 4 points. And use these 4 points for other feature construction. Is this...
Channel: PC-DMIS Portable
04-23-2014, 03:13 PM -
by beerisgoodHello experts.
First off, I'm using pcdmis version 3.5MR2. I have a part that sits on a fixture. I've done the standard tooling ball...-
05-09-2008, 08:32 AM -
by Jonathan SIs it possible to report the deviation of individual points from an auto circle? Other auto features?
03-11-2006, 09:37 AM -
by Stephen1055I'm using PC-DMIS 2012
I have 3 partial circles measured (that would actually be part of a whole circle if other features weren't in the...-
02-27-2017, 08:34 AM -
by zox20I want to do a 3d best fit alignment using 8 constructed points I manually inputted with no CAD and no existing axis system in place. 4 are nominal values...
08-03-2012, 05:33 PM -
