Datums in the true position dialogue box.
  • Datums in the true position dialogue box.
    Hi,
    I changed jobs and my new company has the exact same PCDMIS program as the old company. However, when I go to the GD&T dialogue boxes it is totally different.
    For example, on true position you could create datums and draw the True Position callout in the dialogue box exactly like it was on the print. Now, you can't even create your datums
    or select MMC or anything. I know I'm missing something simple. LOL
    Thanks,
    Jason
    Go to Menu and select Dimension, then click on Legacy to remove it from Legacy Mode and the XactMeasure FCF Dialog window will be active for all GD&T.
    Rob Jensen
    Product Owner - GD&T
    Metrology Software, Inc. - Hexagon Manufacturing Intelligence
      Thanks very much! I knew it had to be a setting, because it was the same version.
      Sincerely,
      Jason
        Keep in mind that Legacy and Xactmeasure will check the part differently. Close, but not the same.
        There are many here that can explain the differences far better than I.
        • bcopher
          True Position Using Datums?
          by bcopher
          This will probably be a very stupid question for most of you, but I want to know how to set it up right! We are using 4.3 on 2 of our CMM's and 4.2MR1...
          07-26-2008, 05:04 PM
        • 12345
          true position dialog box
          by 12345
          V2011 MR1
          Any way to bring back the old true position dialog box (strongly dislike the new one in V2011)
          I've been copying an old true position...
          07-17-2012, 11:32 AM
        • RSNICKER
          True Position
          by RSNICKER
          Why is it that I get different numbers when I report true position in the legacy dimensions than what I get in the new true position report and if so...
          01-23-2009, 12:41 PM
        • Ken8282
          True Position
          by Ken8282
          I recently did a true position and may 321 alignment to the datums and picked the feature to be true positioned but I get a smaller TP than if I do a...
          04-30-2018, 02:38 PM
        • Bob Pierce
          True Position Options
          by Bob Pierce
          V4.3 Legacy dimensions
          Can anyone explain the following:
          I am aligned to the datum reference frame on the drawing. Below this alignment...
          08-29-2008, 08:34 AM
