Does anyone here use Shank probes? Any thoughts on them? Just want to hear what others think of them.
Shank Probes
Pretty much useless. While Pcdmis allows a 'shank calibration', it does not USE the shank calibration, it was an aborted addition to the software that was never finished. If you are not 100% perp/parallel to what you are measuring, you get bogus values.sigpic
- Likes 1
I had some injected molded plastic parts. Circular rings that were press-fit into locomotive breaking assemblies. The ODs were conical (opening up and out to my advantage)..but the height of the cone could vary ±0.03" per print. So, instead of increasing cycle time & making alignments to find the top, or intersecting the OD cone with the top (and constantly beeping over flash [flash = plastic burr for all of you non plastic folks] and getting junk numbers that would p!$$ everyone off) I used a shank to beep the OD. I felt comfortable doing this because the tolerances of the ODs themselves were ±0.006" or greater and the CMM was being used to detect if there was a "problem"...the actual acceptance of the OD itself was a fit/form/function check by my company's Final Insp Dept.
On any machine I have used (all TP20 or HP-TM[US] tri-lobe probing systems), shanks aren't the most accurate and I normally wouldn't use them but they were good for me in that circumstance. I remember getting STDDEV of like 0.00025/0.0003ish when qualifying.
What are you thinking doing?
No matter what you do, make sure you can correlate your CMM results with established methods before using it as your PASS/FAIL.Last edited by DAN_M; 08-05-2019, 06:42 AM.
- Likes 1
We have them. Back in the DAY, if a part had a thread on it thats what was used to minimize probe changes..... That being said for all the downfalls with them, we never had a part rejection that we could base on a shank probe. When we have time we are eliminating them from older legacy programs and do not program new parts with them.
I found them very useful when it come to sheet metal or welded parts, keep in mind, because of the bending and warping, They are not as inaccurate as others may say. After runnng several test and different levels of the shank, getting repeatability and when actually laying parts out and being within a couple of tenths, I would rate them as a very dependable probe.
Shhhhh, don't tell anyone, but I'm pretty sure if they didn't work, they wouldn't make them anymore.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
- Likes 1
I use the 1mm and 2mm fairly often but always as the last option which is usually trying to measure on a very thin surfaces. I've always tried to maintain my hits fairly close to the radius of the shank and never go too high. Never had an issue with R&R or correlation with alternate methods like comparators and micrometers and our newer addition, the 443 Optiv cam CMM.
by HunterS1103Hello All,
Below is a screenshot of the function i'm curious about. Under the probe calibration list there is a Shank Qualification check...-
11-22-2021, 12:56 PM -
by mconklinI am looking to buy some new probes and was wondering if anybody had some good sites to look at
11-29-2010, 12:14 PM -
by ReeceCan I use a 1X35 shank or a 3mm Cylinder to scan. I don't see any of these types of probes in the Probe Description Drop down Box. Using Renishaw SP...
08-07-2014, 11:10 AM -
by metalfabpmrunning infinite 2.0 portable pc-dimis cad 4.3 need more probes. looking to purchase 60 & 90 deg x 150mm point & ruby tip.
what are the...-
09-23-2010, 10:00 PM -
by metalfabpmHas any one purchased romer factory hook probes? If you have what are the pros & cons. I have been able to measure points accuratly for now, but the...
Channel: PC-DMIS Portable
04-16-2012, 10:57 AM -
