Where do I change (if possible) the folder that results from and auto-calibrate program go to? Some (4 probes) of the results are going to a prb file in hexagon 2016, but others (3 probes) are going into a folder 'Calibration' located in the same main folder that many programs are kept. Auto cal program was created by someone no longer with the company. I just want them going to the same place (preferably where pc-dmis gets time stamps for sending warnings about 'probe not calibrated recently'
Auto-calibration results going to different folders
What results are you talking about? The text file that ends in ".results" or a report that the program saves? The results file that PC-DMIS automatically creates is always saved in the same location as the probe file. I've never heard of a program pulling probe files from different locations so I'm guessing that the .results file isn't what you mean, but correct me if I'm wrong.
If it is a report that the program is creating, then without the code from the program it's just a guess as to what's happening. Can you post the code from the program?PC-DMIS 2016.0 SP8
Jeff
This is the program, and also a snip of where the probe files areAttached Files
Originally posted by swisk212 View PostWhere do I change (if possible) the folder that results from and auto-calibrate program go to? Some (4 probes) of the results are going to a prb file in hexagon 2016, but others (3 probes) are going into a folder 'Calibration' located in the same main folder that many programs are kept.
Ok, that's settled and now on to the real issue: do you have the skill/knowledge level to successfully repair and/or upgrade the former programmer's work?
Have you gone thru the auto-cal program and understood everything that's happening there? Do you see which method he/she was using to create, populate, and store these calibration results?
You can learn quite a bit from just tracing the methodology of an advanced programmer. You see extra steps and wonder why, then later see diverging paths or validation actions that depend upon those seemingly superfluous steps. Good (IMO) programmers will leave copious and detailed notes in the form of $$ comments throughout the tangled web of commands, and leave you a solid modular architecture where you can tweak one section without the whole thing crunching to a halt with a vague runtime error.
With luck it's a simple hardcoded filepath to a folder, easy fix.
Close all programs. Go to Edit | Set search path. Then select Probe Directory from the drop down list. Make sure only the "Search specified directory" box is ticked. Then select the location you want to use for all your probes. Next copy all the probes from the different locations and paste them into the location you want to use.
Next time you run that program it should use just the probe files from that specified location.
I never notice that there are other options other than searching a specified directory. That's all we ever use.PC-DMIS 2016.0 SP8
Jeff
Originally posted by Schrocknroll View PostClose all programs. Go to Edit | Set search path. Then select Probe Directory from the drop down list. Make sure only the "Search specified directory" box is ticked. Then select the location you want to use for all your probes. Next copy all the probes from the different locations and paste them into the location you want to use.
Originally posted by Ego Murphy View Post
Good answer but re-read his post. He has a custom auto-cal prg writing results on it's own, not depended upon the Search path... which is not variable and can only be a single path for any single seat of the PC-Demonic.
Code:STARTUP =ALIGNMENT/START,RECALL:USE_PART_SETUP,LIST=YES ALIGNMENT/END MODE/DCC MOVESPEED/ 100 PREHIT/0.125 RETRACT/0.125 FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;MEAS,NOM,TOL,DEV,OUTTOL, , DISPLAYPRECISION/5 LOADPROBE/SERVICE TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, Install Calibration Sphere with adapter into AC22 on CMM COMMENT1 =COMMENT/INPUT,YES,FULL SCREEN=NO, 'Employee initials' COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, Probe is going to index. Make sure there is enough room. AUTOCALIBRATE/PROBE, PARAMETER_SET=ALL-TIPS-WITH-DEFAULTS, QUALTOOL_MOVED=YES_DCC, SHOW_SUMMARY=YES, OVERWRITE_RESULTSFILE=NO BEGIN AUTOCALIBRATE RESULTS FOR PROBE SERVICE USING SET ALL-TIPS-WITH-DEFAULTS Probe file=SERVICE Date=8/3/2019 Time=9:42:01 AM m8903 CENT X 6.78269 Y 11.02415 Z-17.13333 D0.98348 T1A0B0 THEO X 0.00000 Y 0.00000 Z 8.46732 D0.07874 T1A0B0 MEAS X -0.00048 Y -0.00033 Z 8.46429 D0.07836 StdDev0.00004 END AUTOCALIBRATE RESULTS FOR PROBE SERVICE USING SET ALL-TIPS-WITH-DEFAULTS LOADPROBE/TIP1 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 AUTOCALIBRATE/PROBE, PARAMETER_SET=ALL-TIPS-WITH-DEFAULTS, QUALTOOL_MOVED=NO, SHOW_SUMMARY=NO, OVERWRITE_RESULTSFILE=NO LOADPROBE/TIP2 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 AUTOCALIBRATE/PROBE, PARAMETER_SET=ALL-TIPS-WITH-DEFAULTS, QUALTOOL_MOVED=NO, SHOW_SUMMARY=NO, OVERWRITE_RESULTSFILE=NO LOADPROBE/TIP3 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 AUTOCALIBRATE/PROBE, PARAMETER_SET=ALL-TIPS-WITH-DEFAULTS, QUALTOOL_MOVED=NO, SHOW_SUMMARY=NO, OVERWRITE_RESULTSFILE=NO LOADPROBE/TIP4 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 AUTOCALIBRATE/PROBE, PARAMETER_SET=ALL-TIPS-WITH-DEFAULTS, QUALTOOL_MOVED=NO, SHOW_SUMMARY=NO, OVERWRITE_RESULTSFILE=NO LOADPROBE/TIP5 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 AUTOCALIBRATE/PROBE, PARAMETER_SET=ALL-TIPS-WITH-DEFAULTS, QUALTOOL_MOVED=NO, SHOW_SUMMARY=NO, OVERWRITE_RESULTSFILE=NO LOADPROBE/TIP6 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 AUTOCALIBRATE/PROBE, PARAMETER_SET=ALL-TIPS-WITH-DEFAULTS, QUALTOOL_MOVED=NO, SHOW_SUMMARY=NO, OVERWRITE_RESULTSFILE=NO LOADPROBE/SERVICE TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 AUTOCALIBRATE/PROBE, PARAMETER_SET=ALL-TIPS-WITH-DEFAULTS, QUALTOOL_MOVED=NO, SHOW_SUMMARY=NO, OVERWRITE_RESULTSFILE=NO PRINT/REPORT,EXEC MODE=END,$ TO_FILE=ON,AUTO=1,AUTO OPEN REPORT=OFF,$ TO_PRINTER=OFF,COPIES=1,$ TO_DMIS_REPORT=OFF,FILE_OPTION=INDEX,FILENAME=,$ REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMENSIONS=NO,$ TO_EXCEL_OUTPUT=OFF, PREVIOUS_RUNS=KEEP_INSTANCES WORKPLANE/ZPLUS LOADPROBE/TIP3 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0
Jeff
Back at it, just did as you suggested Edit / search path. I will try to sneak in auto cal during the day (cmm has been busy this week - work load for it changes drastically). As to my capabilities, I took level 1 Hexagon training (hoping to take level 2 this fall), but I am by no means a 'coder' etc. Most programs required are relatively standard (a few using cad or differing work planes , cylinders with angled cut outs etc). Thank you for the advice thus farLast edited by swisk212; 08-07-2019, 08:03 AM.
by ErikirThis has probably been asked and answered before, but my search turned up 500 results...
I used to know where they're stored, but I'm experiencing...-
09-29-2014, 02:33 PM -
by Robert EomMy customer use 10 machines in their factory.
They use many probes and dock table.
They calibration all of probes and angles...-
02-13-2020, 12:48 AM -
Hi there.
My first post !!!!!!!!!!!!
I've only been using PCDMIS since Dec '07, and up to now, I've managed to get out of...-
03-26-2008, 09:26 AM -
by AuRulesYesterday day I finally had my little male dog of 15 years put to sleep. I mentioned it in a earlier thread a couple a months ago, but every time we took...
05-19-2009, 06:38 AM -
by SI_GUY_29Ok, I know this error is covered in another post, but I just wanted to get an answer from what one of the post said for troubleshooting the error. It...
07-17-2017, 08:02 AM -
