Merged Model not visible
  • Merged Model not visible
    Good morning,
    i'm trying to compare my CMM programs to the CNC programming models. Sometimes our CNC programmers add tooling tabs w/ holes or are unable to cut features as originally planned.
    (trying to avoid crashes.) But importing and merging the .STL file on top of my model (usually .stp) isn't showing the merged model, only the original.
    Anyone else had this issue?
    sigpicV2014mr1
    What version?Try going to the cad assembly utilities window sometimes in here if you have 2 or models merged some may not show because of here select both that are in this window and then place a check mark for both models cad assembly Capture.JPG
    Michael A Wildschutz Sr
    I Walk on The WildSide
    "To Each is Own"
      Thank you MWS
      the boxes are checked but only my original model is showing. V2015.1
      sigpicV2014mr1
      • michaelwildschutz
        michaelwildschutz commented
        in that same cad assembly window did you expand them all to make sure everything is selected like my pic here
      "To Each is Own"
        i would also look into the cad levels window and the cad groups window you never know how someone added a feature to the original cad model..Also try view setup in the levels area there may be another model that is not selected .(my window only shows a zero selected there may be another selection there
        "To Each is Own"
          Well, your suggestions have helped me view my merged model. Checking the boxes. Thanks!
          sigpicV2014mr1
            mtalla thanks for asking and Michael thanks for answering. I've been having a problem with an entire model not showing up. The engineer that made it tried a thing or two but nothing worked. The CAD Assembly showed the check mark in the model. I never even thought to expand it! Sure enough, there was another level that was unchecked.
              your welcome DSylver
              "To Each is Own"
                Its a nice option when you want to import a entire loading fixture and clamps along with your part model and you can turn on and off items in the list like clamps or studs that may be in the way for some reason or another.
                "To Each is Own"
                  Another place to look would be in Edit>Graphic Display Window>Cad Levels.
                  • Mike Ruff
                    Mike Ruff commented
                    This was already mentioned. See #5 above
                • MJSmith
                  cad models
                  by MJSmith
                  I am programming a part off the model and was about 50% of the way done when I left for the night. When I opened up the file the next day the model was...
                  05-09-2017, 03:09 PM
                • Vertman
                  Model Identity within programs.
                  by Vertman
                  Morning all.
                  I am currently working on some short lead time gearbox casings , 3 parts to each set, which are being constantly up issued,...
                  01-06-2009, 04:07 AM
                • Marken199
                  Transform a model
                  by Marken199
                  So, I just found out the model I have in my program is off .0005 in in Z. It needs to be shifted up .0005. I know how to transform the model, I just...
                  11-26-2019, 10:04 AM
                • mconklin
                  merging a model
                  by mconklin
                  I have a question on merging models in pcdmis. Is it possible to merge in a new model with a old model on a old program for a part roll.
                  11-15-2010, 02:50 PM
                • rmassarini
                  Bad Model Import
                  by rmassarini
                  So, I received a model, converted to an igs and imported to PCD. Some features were missing or just out in space, I tried stp and slt formats also and....same...
                  05-02-2017, 06:35 PM
