IF GOTO Statements for Reporting
  • IF GOTO Statements for Reporting
    I'm trying to use IF/GOTO statements to control when the report should print and when it should not. COMMENT1.INPUT will always be either STARTUP or a number that is greater than 0. Basically I want a report generated in both cases but only a report printed in the case where COMMENT1.INPUT is not STARTUP. Not sure what I'm doing wrong or missing. Right now it is executing both Print report commands. Any ideas for how to make this work? Thank you!
    IF_GOTO/COMMENT1.INPUT=="STARTUP",GOTO = L1
    IF_GOTO/COMMENT1.INPUT>0,GOTO = L2
    L1 =LABEL/
    PRINT/REPORT,EXEC MODE=END,$
    TO_FILE=ON,OVERWRITE=VAL_FILE,AUTO OPEN=OFF,$
    TO_PRINTER=OFF,COPIES=1,$
    TO_EXCEL=OFF,$
    L2 =LABEL/
    TO_PRINTER=ON,COPIES=1,$
    TO_EXCEL=OFF,$
    For something like this you might want to try a Case statement instead of the IF/GOTO. You can search for threads that cover this subject well.
    The quick fix would be to put a GOTO statement (to L3 or something) after the first print command and then put a L3 label after the second print command
      https://www.pcdmisforum.com/forum/pc...partial-report
        Thanks so much. I got it working. Appreciate it.
        • KIRBSTER269
          KIRBSTER269 commented
          share with people what you did to get it working, so that others may learn.
        You have nothing that prevents print report after L1 from jumping over/skipping L2 code. add a goto at end of L1, to skip L2.
        L1 =LABEL/
        TO_EXCEL=OFF,$
        [B]goto/endpgm[/B]
        L2 =LABEL/
        TO_EXCEL=OFF,$
        [B]endpgm=label/[/B]
        Question, what if someone typed in an invalid number, or "START UP" with a space? Or "PEISS OFF DEMON"? you should have a validation loop in the comment that FORCES operator to provide a correct input. I'm pretty sure this should work, but you get the point either way.
        [B]com1in=label/
        comment1: what's the routine you want?[/B]
        [B]ELSE/goto=com1in
        endelse/[/B]
        L1 =LABEL/
        TO_EXCEL=OFF,$
        [B]goto/endpgm[/B]
        L2 =LABEL/
        TO_EXCEL=OFF,$
