Angle output from a cone
  • Angle output from a cone
    Does anyone happen to know if there is a way to output an angle dimension for a report from a cone?
    yes, click location dimension icon, click the box next to "A" which is for angle. if you need the half angle , in the middle of the same dialog box, there is a "A/2" box or it will say half angle depending on your version, for the half angle. Check your tolerances because checking the A/2 box will also divide your tolerances by 2 as well. You can always fix your tolerance.
      Well, that was easy. Thanks!
