We have 3 Global models of Hexagon CMMs, and two of our machines have an automatic retract after taking manual hits. However one of our machines does not have the automatic retract, which makes taking manual points very tedious having to back out of each point trying to avoid taking multiple hits. Is there a way to fix this and have it retract on all machines?
Scan head automatic retract
Type (manretract) and set value in beginning of program
ALIGNMENT/END
MODE/MANUAL
MANRETRACT/2
PREHIT/2
RETRACT/2
CHECK/2,1
MOVESPEED/ 250
DISPLAYPRECISION/4
TOUCHSPEED/ 2
FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;MEAS,NOM,TOL,DEV,OUTTOL, ,
LOADPROBE/T1_2X20MM
Remember that using manretract you need to be careful that the vector direction of travel is read properly. If you sneak up on your hits (get real close) and take a point it can read the vector direction backwards, and it will retract in the same direction that you drove it into the part. so if you are taking a hit straight down it will drive down into part as the retract direction.Last edited by William Johnson; 07-31-2019, 07:07 AM.Time for the Trolls to leave.
Originally posted by William Johnson View PostI have never used that. How does it work? I thought that most of these settings were for scanning heads.PC-DMIS 2016.0 SP8
Jeff
I think you have to access the controller to turn that option on, our service tech did it for us.
Maybe that controller won't support it, are they all the same model and vintage?
I am writing a program that has a measurement of small grooves. I put in a prehit and retract distance of 50 microns into the program, but when I go to...
07-26-2017, 08:29 PM -
by gcunniffRunning an iterative alignment using several 7mm x 13mm slots. I have the Prehit and Retract set to 2mm, but during the manual point selection process,...
02-19-2013, 07:31 AM -
by Stuart_WardI am using an advantage CMM with a tesa star head with a LEITZ_LSPX1H_T.
Is there a way of turning off the automatic retract after taking...-
12-06-2013, 01:30 PM -
by ScottP815So this is probably a pretty dumb question but here goes. I have version 2020 R1. I am trying to get my probe retracted to change. So I went into the...
12-18-2020, 10:41 AM -
