Okay. What I've got going on is my X deviation (at most) is at .0132" off nominal.
My Y deviation is (also at most) .0083 off location.
Nominal hole diameter is .4527", plus or minus .0196", with a measurement of .453".
True position tolerance is .0196 at MMC in relation to A,B,&C., and .01 to itself.
Everything I'm seeing tells me that while it's ugly, the hole pattern should fall into TP tolerance, because of MMC, but the CMM is telling me that the pattern, while well in tolerance to each other is .197 OOT in relation to the datums.
What have I got going on?
(yes. In the interest of brevity, I deleted many scan hits)
A2 =ALIGNMENT/START,RECALL:A1,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN2 ALIGNMENT/ROTATE,YPLUS,TO,LIN3,ABOUT,ZPLUS ALIGNMENT/TRANS,XAXIS,PNT1 ALIGNMENT/TRANS,YAXIS,PNT1 ALIGNMENT/TRANS,ZAXIS,PNT1 ALIGNMENT/END MOVE/POINT,NORMAL,<-8.294,-5.899,0.25> SCN1 =BASICSCAN/CIRCLE,NUMBER OF HITS=23,SHOW HITS=YES,SHOWALLPARAMS=NO HIT/VECTOR,<-8.5211,-5.9123,0>,<0.9982963,0.0583474,0>,<-8.519,-5.899,-0.0003>,T=0.0029 ENDSCAN CIR1 =FEAT/CIRCLE,CARTESIAN,IN,LEAST_SQR,NO THEO/<-8.294,-5.899,0>,<0,0,1>,0.455 ACTL/<-8.2926,-5.8858,-0.0001>,<0,0,1>,0.4545 CONSTR/CIRCLE,BF,2D,SCN1,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 DIM LOC1= LOCATION OF CIRCLE CIR1 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS +TOL -TOL DEV OUTTOL X -8.2940 -8.2926 0.0100 0.0100 0.0014 0.0000 -----#--- Y -5.8990 -5.8858 0.0100 0.0100 0.0132 0.0032 --------> D 0.4527 0.4545 0.0196 0.0196 0.0017 0.0000 ----#---- END OF DIMENSION LOC1 A3 =ALIGNMENT/START,RECALL:A2,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN2 ALIGNMENT/TRANS,XAXIS,SCN1 ALIGNMENT/TRANS,YAXIS,SCN1 ALIGNMENT/TRANS,ZAXIS,SCN1 ALIGNMENT/ROTATE,YPLUS,TO,LIN3,ABOUT,ZPLUS ALIGNMENT/END MOVE/POINT,NORMAL,<-0.0055,-0.0114,0.5> MOVE/POINT,NORMAL,<-1.5445,-0.0114,0.5> SCN2 =BASICSCAN/CIRCLE,NUMBER OF HITS=25,SHOW HITS=YES,SHOWALLPARAMS=NO HIT/VECTOR,<-1.7717,-0.0226,0>,<0.9987792,0.0493967,0>,<-1.7681,-0.011,-0.0004>,T=0.0042 ENDSCAN CIR2 =FEAT/CIRCLE,CARTESIAN,IN,LEAST_SQR,NO THEO/<-1.539,0,0>,<0,0,1>,0.455 ACTL/<-1.5418,0.0002,0>,<0,0,1>,0.4535 CONSTR/CIRCLE,BF,2D,SCN2,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 DIM LOC2= LOCATION OF CIRCLE CIR2 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS +TOL -TOL DEV OUTTOL X -1.5390 -1.5418 0.0100 0.0100 -0.0028 0.0000 ---#----- Y 0.0000 0.0002 0.0100 0.0100 0.0002 0.0000 ----#---- D 0.4527 0.4535 0.0196 0.0196 0.0008 0.0000 ----#---- END OF DIMENSION LOC2 MOVE/POINT,NORMAL,<-1.5445,-0.0114,0.5> MOVE/POINT,NORMAL,<0.496,-3.95,0.5> SCN3 =BASICSCAN/CIRCLE,NUMBER OF HITS=25,SHOW HITS=YES,SHOWALLPARAMS=NO HIT/VECTOR,<0.2688,-3.9375,0>,<0.9984977,-0.0547929,0>,<0.2655,-3.9458,0.0001>,T=-0.0028 HIT/VECTOR,<0.2694,-3.9298,0>,<0.9960388,-0.0889198,0>,<0.2674,-3.9382,-0.0004>,T=-0.0012 ENDSCAN CIR3 =FEAT/CIRCLE,CARTESIAN,IN,LEAST_SQR,NO THEO/<0.496,-3.95,0>,<0,0,1>,0.455 ACTL/<0.4924,-3.9583,0>,<0,0,1>,0.4537 CONSTR/CIRCLE,BF,2D,SCN3,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 DIM LOC3= LOCATION OF CIRCLE CIR3 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS +TOL -TOL DEV OUTTOL X 0.4960 0.4924 0.0100 0.0100 -0.0036 0.0000 --#------ Y -3.9500 -3.9583 0.0100 0.0100 -0.0083 0.0000 #-------- D 0.4527 0.4537 0.0196 0.0196 0.0010 0.0000 ----#---- END OF DIMENSION LOC3 MOVE/POINT,NORMAL,<0.496,-3.957,0.5> MOVE/POINT,NORMAL,<3.637,-1.102,0.5> SCN4 =BASICSCAN/CIRCLE,NUMBER OF HITS=25,SHOW HITS=YES,SHOWALLPARAMS=NO HIT/VECTOR,<3.4098,-1.0897,0>,<0.9985434,-0.0539547,0>,<3.4105,-1.0977,-0.0002>,T=0.0011 HIT/VECTOR,<3.4103,-1.0828,0>,<0.9964229,-0.0845066,0>,<3.4092,-1.0907,0>,T=-0.0005 ENDSCAN CIR4 =FEAT/CIRCLE,CARTESIAN,IN,LEAST_SQR,NO THEO/<3.637,-1.102,0>,<0,0,1>,0.455 ACTL/<3.6353,-1.1099,0.0001>,<0,0,1>,0.4534 CONSTR/CIRCLE,BF,2D,SCN4,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 DIM LOC4= LOCATION OF CIRCLE CIR4 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS +TOL -TOL DEV OUTTOL X 3.6370 3.6353 0.0100 0.0100 -0.0017 0.0000 ---#----- Y -1.1020 -1.1099 0.0100 0.0100 -0.0079 0.0000 #-------- D 0.4527 0.4534 0.0196 0.0196 0.0007 0.0000 ----#---- END OF DIMENSION LOC4 MOVE/POINT,NORMAL,<3.637,-1.102,0.5> MOVE/POINT,NORMAL,<5.154,-3.957,0.5> SCN5 =BASICSCAN/CIRCLE,NUMBER OF HITS=25,SHOW HITS=YES,SHOWALLPARAMS=NO HIT/VECTOR,<4.9269,-3.9442,0>,<0.9984131,-0.0563137,0>,<4.9216,-3.9524,-0.0004>,T=-0.0048 HIT/VECTOR,<4.9276,-3.935,0>,<0.9953103,-0.0967333,0>,<4.9218,-3.9432,0>,T=-0.005 ENDSCAN CIR5 =FEAT/CIRCLE,CARTESIAN,IN,LEAST_SQR,NO THEO/<5.154,-3.957,0>,<0,0,1>,0.455 ACTL/<5.148,-3.9652,0>,<0,0,1>,0.4542 CONSTR/CIRCLE,BF,2D,SCN5,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 DIM LOC5= LOCATION OF CIRCLE CIR5 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL MEAS +TOL -TOL DEV OUTTOL X 5.1540 5.1480 0.0100 0.0100 -0.0060 0.0000 -#------- Y -3.9570 -3.9652 0.0100 0.0100 -0.0082 0.0000 #-------- D 0.4527 0.4542 0.0196 0.0196 0.0015 0.0000 ----#---- END OF DIMENSION LOC5 DATDEF/FEATURE=PLN2,A DATDEF/FEATURE=PLN3,B DATDEF/FEATURE=LIN3,C FCFLOC1 =POSITION : CIR1,CIR2,CIR3,... FEATCTRLFRAME/SHOWNOMS=NO,SHOWPARAMS=YES,SHOWEXPANDED=YES CADGRAPH=OFF,REPORTGRAPH=OFF,TEXT=OFF,MULT=10.00,A RROWDENSITY=100,OUTPUT=BOTH,UNITS=IN COMPOSITE=YES,FIT TO DATUMS=YES,DEV PERPEN CENTERLINE=ON,OUTPUT ALIGNMENT=Datum Reference Frame CUSTOMIZED DRF=NO STANDARDTYPE=ASME_Y14_5 SIZE TOLERANCES/5DIAMETER,0.4527,0.0196,0.0196 PRIMARY DIMENSION/POSITION,DIAMETER,0.0197,MMC,A,B,C SECONDARY DIMENSION/,DIAMETER,0.0098,MMC,<dat>,<dat>,<d at> NOTE/FCFLOC1 FEATURES/CIR1,CIR2,CIR3,CIR4,CIR5,,
