Scan speed will not change
  • Scan speed will not change
    I have a program for a tight tolerance part that I want to scan portions slowly, then speed the scans up for other portions.
    No matter what scan speed I put in the machine won't speed back up to where I want to be.
    Global advantage
    PC-DMIS V2014.1
    LSPX3 probing system.
    I tried changing the usescanspeedasbasis as was recommended by our service tech.
    where are you adjusting the scan speed. ive only had it work changing the scan speed in the auto feature dialogue box for the individual features.
    • BKulpa
      BKulpa commented
      These are linear open scans, not autofeatues.
    If I'm not mistaken, I've cut and pasted the scanspeed section of the program, and gotten the same result. Reading the OP's question brings back horrible memories of frustration.
    Thanks, ever so.
      Whenever I adjust the scan speed, I always change the scan acceleration in the option probe settings along with it. If you change both, you'll see a difference.
      • BKulpa
        BKulpa commented
        I'll give it a try this morning, but it only happens on one of fifteen machines that are all the same.
