I have a headscratcher here. I have a part with a bore, in said bore is a "grease slot" that is pitched. However it is never in the same orientation. It could start anywhere in in 360 degrees and seems to change orientation depending on which operator is running (probably has something to do with the rapids on the machine) I am wondering if there is a way to filter and omit bad hits (those which fall in the groove). Clearly changing strategy for each part would not be efficient.
Bore woes!
By the looks of it you are only taking what 6 hits on each cut of the cylinder? You have a touch probe, no scanning head, correct?
add label redoc1
add comment/input asking if helix of grease slot is going down clockwise (1) or counterclockwise (2)
make assign/v1=if(c1.input<>1 OR 2,goto==redoc1,if(c1.input==1,"CCW","CW") makes sure input is valid, then makes cylinder vector clockwise or counterclockwise
Then, just before measuring the bore, put another operator input to move stylus so it is directly over the slot start. add a readpoint from there.
Align/rotate about center of bore to the readpoint.
Measure your cylinder with the 6 hits per cut, with the vector direction (cw or ccw) determined by v1. add helix angle to pitch diameter, looks like it would go around in a full circle? so pitch = cyl axis length
Note obviously set start angle at like 30° away from -rotated to- grease slot 0 and end angle at 390°Last edited by louisd; 07-29-2019, 05:01 PM.
- Likes 2
by OhmasI'm having kind of headache with this.
It's a cylinder with 8 slots at the end, positioned to Datum B (outer cylinder) by 0,05, and relative to...-
11-21-2016, 04:40 AM -
by thomasGood Day all,
I had it but then I lost it! I have a part that has a slot that I need to measure. The slot is .124+-.001 x .141+-.002 and .180+-.003...-
10-13-2009, 11:39 AM -
by JLHUTTI am very new to this and I am sure it's a simple answer, but at the moment it has me stumped. I am checking a part that is a rectangle shape with a...
01-15-2008, 07:50 AM -
by olivia311I'm currently laying out a part with many relatively narrow slots (2.02 mm x 25.5 mm.) I need to measure the slot minor (diameter) and slot major dimensions...
04-24-2014, 08:49 AM -
by HemingThe repeatibility of the angle I measured and the center of a slot is nowhere near what I hoped. Even the same part, I measured twice the angle values...
07-06-2010, 02:10 PM -
