Scanning
  • Scanning
    I am really struggling with scanning
    I have a profile I need to scan on a recessed O.D.
    I have tried all the different types of scanning and cannot seem to find a solution
    its an odd shape and I'm just wanting the probe to go in and follow the shape of it and compare it to the model.
    any help?
    Have you tried Perimeter scan?
    • Ekneel28@gmail.com
      [email protected] commented
      Yes and I can’t seem to get it to do it
      Maybe I am doing something wrong?
      It’s very difficult to get support and I haven’t found the help index useful.
    We have the Lspx analog scanning head on the brown and sharp global
      have you tried open or closed scan?? that what i would use
        when using open and closed scans make sure your z height on yours start, direction and end points are all the same and that you have all the surfaces slected that are between your start and end points and make sure your on nullfilter and defined , findnons and your boundary type is plane
          Will these settings you just described work on the contour shown in the pic?
        • thomas pilc
          thomas pilc commented
          ya should and make sure you do what kirbster pointed out as well
        highlight the surfaces to be scanned, and unhighlight the ones that you are not, before generating points, also you might have to add crossings or subtract them
        • KIRBSTER269
          KIRBSTER269 commented
          not to be rude, but how much do you know about scanning?, Honesty will get you everywhere, dishonest will get you nowhere. I can provide step by step pictures, really don't want to, but I will.
          I took the scanning in 202 class last year and am just now needing it so I know absolutely blahh!
        • KIRBSTER269
          ok give me a few. I'll make a linear open example.
        linear close seems to be graphing great. found my issue to be the point density was set too high.
        I lowered it and now its contouring around it nicely.
        was set at.1 and I dropped it to .005! huge difference!
          Thanks guys!
          its really appreciated every time everything
            I use Nullfilter,
            First Tab these are my Settings.
            Then of course Choose your Start, Direction, and End Points
            Once you placed them on your Cad Model, double click on the 1 on your boundry points, here you want to set the depth of all 3 points the same, Maybe it's in X, maybe Y, or maybe Z.
            Then Go to the next Tab, Graphics Click on Select, Go Highlight your surfaces
            Then You can go To Settings, Choose what favors you and hit apply, Mine I setup in Settings Editor so they always stay these numbers by default.
              Then go back to Path Definition and click Generate, Then Create
                Thank you Kirbster for taking the time to do this.
                very much appreciated.
              Yeah, my density is set to 0.002" (0.050MM) for EVERYTHING I scan. Your density value was too high, density was too low.
              • 2013_junkie
                Analog Scanning
                by 2013_junkie
                So first and foremost, I'm completely wet behind the ear with scanning. We have decided to add scanning to a few of our machines, so while we are waiting...
                01-08-2018, 11:53 AM
              • Darrollh
                Scanning
                by Darrollh
                Good afternoon,
                I want to use a scan to report out a profile. However, the machine I use don't have a scanning probe head. I using a Hexagon Global...
                12-09-2019, 04:06 PM
              • BSchwark
                Scanning Question?
                by BSchwark
                SP-600 Global 3.7MR2.
                I am trying to scan using customer program. Everthing runs good until I reach the scanning portion of the program. The portion...
                06-19-2006, 03:36 PM
              • mattias
                continues scanning
                by mattias
                I'm using probe SP25. It should use continues scanning instead single points scanning. What should I switch to have real scanning?
                01-14-2015, 02:22 PM
              • Darrollh
                Scanning Basics
                by Darrollh
                Good morning,
                I am beginning to get a few parts in that require scanning, something I have very little experience in. Can some help me with the...
                10-05-2017, 09:25 AM
