I'm trying to use legacy dimensioning to apply MMC for a couple datums for profile of a surface (both form and location). There doesn't seem to be any of the buttons to select MMC, LMC, or RFS on here. Is there any way to do this with legacy?
MMC for profile of a surface
Originally posted by bfire85 View PostCan't do it in legacy. You can in Xact. Question: Do you REALLY need it?sigpic
CMMXYZ Applications Specialist: PC-DMIS Support and Training. Check out my PC-DMIS tutorial videos... https://blog.cmmxyz.com/blog/tag/cmm-tech-tips
Not only profile, you should never use MMB in legacy. It's wrong and just add in values as additional tolerance instead of calculating datum shift. Use Xact measure if you need to use material conditions on datums. This has been a giant pit trap for new users to fall in that has never been filled.
Originally posted by Trevor McLaughlin View PostDisable Legacy Dimensions and use Xact Measure for Surface Profile. You can then use a modifier on your datums.
No, I would leave that field alone. It's meant for defining a specific MMB size, if the implied boundary is not clear. If you open the Nominals tab of your dimension dialog, you will see your datum feature in a list where you can define both the nominal size and the tolerance. The amount your measured datum feature deviates from nominal will determine the amount of datum shift.
Here's what the Help files say on the subject of defining a specific boundary size:
Stating a Specific Boundary
If you want to define a specific boundary, perhaps because the implied boundary is not clear, you can use the Feature Control Frame Editor to explicitly state the boundary by enclosing it within brackets immediately following the applicable datum feature reference and any modifier following that datum feature reference. This value represents the size of the material boundary. PC-DMIS uses it to calculate the bonus on the datum feature, disregarding any preceding position or orientation tolerances on the datum feature:
by kalepitoi have this probelm i need the surface profile of a plane and my datum A is another plane my B is a hole and C another hole
the FCF surface profile...-
04-27-2010, 12:18 PM -
by psalm2Can you pick up a bonus tol on profile of a surface when you have the MMC modifer on the -B- and -C- datums? If so how do I show that in my report. I...
08-22-2006, 08:44 AM -
by GEO3DThis is the first time I've tried to attach a file so I hope this works :-)
I’m trying to figure out how to measure a radius...-
07-06-2015, 06:49 AM -
by bgrahamusing a scan to check a profile of a surface. how would i report true position of that profile (scan) using MMC?
Xactmeasure will not allow MMC...-
08-05-2013, 08:42 AM -
by Paul RWe need to check the surface profile of a straight edge with the secondary datum at MMC. Is this possible with PC DMIS PRO V2011? I know we can check...
01-30-2013, 12:49 PM -
