Been away from this for awhile just getting back into it. can't remember this but when programming in the graphics window how do you show active probe on screen.
Probe in graphics window.
Sorry I didn't explain myself better. what I'm looking for is that in 2017 you could go to insert machine, pick your machine apply, close then open that window up again and answer the question no machine close it and you would only show the probe in graphics window. That way it would show the operator where to take a manual hit when prompted to pick up a surface. It looks like they have removed that option from that menu.
Originally posted by dmis100 View PostSorry I didn't explain myself better. what I'm looking for is that in 2017 you could go to insert machine, pick your machine apply, close then open that window up again and answer the question no machine close it and you would only show the probe in graphics window. That way it would show the operator where to take a manual hit when prompted to pick up a surface. It looks like they have removed that option from that menu.PC-DMIS 2016.0 SP8
Jeff
A tip if your probe is in your way....
Go to EDIT\GRAPHIC DISPLAY WINDOW\LIGHTING/MATERIALS....go to "Lighting" tab. You can make stuff in your graphics window transparent and can see through your probe and still click surfaces even if its in your waySF7107(PCD), SF454(PCD), 152614(Quindos), 9159(Quindos), 7107(Quindos), B&S Manual, M&M Gear Checker
- 2 likes
Thanks schrocknroll I will give that a try. New computer just have 2018 now. I know it worked in 2017. When I get a chance I will download 2017 and give it a try.
by Vertman..... well possibly anyway.
Is there any way that i can get the probe to be visible al the time, not just when it decides to appear take...-
03-12-2009, 11:54 AM -
by ARivard1Hey Guys,
I'm working on a pretty in-depth program using a CAD model, and every time I click on a point to make an adjustment or check...-
09-02-2015, 10:16 AM -
by scharschI was wondering if there is a way to toggle the probe graphics on/off with a button.
When I have the probe inside a part it is difficult to see...-
06-05-2008, 01:51 PM -
Hey everybody... I'm sure this question has been asked before but.... Is there any possible way to keep PC-Dmis from hiding the probe after executing...
11-03-2015, 09:24 PM -
