2019 R2 CAD...
Hi All,
Everything on my op sheet is back to -A- and -B-.
-A- bottom face, MODEL DOES NOT SHOW THIS BUT THE ACTUAL PART HAS A BEVEL GEAR so Datum -A- is interrupted in 100+ places.
-B- is the top ID.
I want to create a datum simulator surface on the top of the inspection risers that the part will be sitting on
Does this all seem legit?
Hi All,
-B- is the top ID.
LOADPROBE/SMALLYELLOW TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 MOVESPEED/ 250*0.9 TOUCHSPEED/ 5 PREHIT/0.25 RETRACT/0.25 CHECK/0.26,1 COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, Put part up on risers (gear face down. Risers making contact with gear face. Risers at 7:00, 11:00, and 3:00 COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, TAKE PART OFF OF THE RISERS. PUT PART IN A SAFE SPOT. COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, Put probe above the center of the 7:00 riser (as shown) RP_7OCLOCK =FEAT/POINT,CARTESIAN THEO/<-1.9313,-3.345,0>,<0,0,1> ACTL/<-1.9313,-3.345,0>,<0,0,1> READPOINT/ MODE/DCC PLN_7OCLOCK=FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,TRIANGLE,LEAST_SQR THEO/<-1.9133,-3.345,0>,<0,0,1> ACTL/<-1.9133,-3.345,0>,<0,0,1> TARG/<RP_7OCLOCK.X,RP_7OCLOCK.Y,0>,<0,0,1> ANGLE VEC=<-1,0,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO MODE/MANUAL COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, Put probe above the center of the 11:00 riser (as shown) RP_11OCLOCK=FEAT/POINT,CARTESIAN THEO/<-1.9312,3.3451,0>,<0,0,1> ACTL/<-1.9312,3.3451,0>,<0,0,1> READPOINT/ MODE/DCC PLN_11OCLOCK=FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,TRIANGLE,LEAST_SQR THEO/<-1.9313,3.345,0>,<0,0,1> ACTL/<-1.9313,3.345,0>,<0,0,1> TARG/<RP_11OCLOCK.X,RP_11OCLOCK.Y,0>,<0,0,1> ANGLE VEC=<0.5,0.8660254,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO MODE/MANUAL COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, Put probe above the center of the 3:00 riser (as shown) RP_3OCLOCK =FEAT/POINT,CARTESIAN THEO/<3.8625,0,0>,<0,0,1> ACTL/<3.8625,0,0>,<0,0,1> READPOINT/ MODE/DCC PLN_30OCLOCK=FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,TRIANGLE,LEAST_SQR THEO/<3.8625,0,0>,<0,0,1> ACTL/<3.8625,0,0>,<0,0,1> TARG/<RP_3OCLOCK.X,RP_3OCLOCK.Y,0>,<0,0,1> ANGLE VEC=<0.5,-0.8660254,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO CIR_READPNTS=FEAT/CIRCLE,CARTESIAN,IN,LEAST_SQR,NO THEO/<0,0,0>,<0,0,1>,7.725 ACTL/<0,0,0>,<0,0,1>,7.725 CONSTR/CIRCLE,BF,2D,RP_7OCLOCK,RP_11OCLOCK,RP_3OCLOCK,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 SCN_PNTS_LOCFACE=FEAT/SET,CARTESIAN THEO/<0,0,0>,<0,0,1> ACTL/<0,0,0>,<0,0,1> CONSTR/SET,BASIC,PLN_7OCLOCK.HIT[1..4],PLN_11OCLOCK.HIT[1..4],PLN_30OCLOCK.HIT[1..4],, PLN_A =FEAT/PLANE,CARTESIAN,TRIANGLE,YES,LEAST_SQR THEO/<0,0,0>,<0,0,1> ACTL/<0.006,0,0>,<0,0,1> CONSTR/PLANE,BF,SCN_PNTS_LOCFACE,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 A1 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN_A ALIGNMENT/TRANS,XAXIS,CIR_READPNTS ALIGNMENT/TRANS,YAXIS,CIR_READPNTS ALIGNMENT/TRANS,ZAXIS,PLN_A ALIGNMENT/END MOVE/POINT,NORMAL,<0,6,6> COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, Put part back up on risers. Rotate part so there is a gear tooth flat approx at 6:00 COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, Press OK for CNC Measurement MOVESPEED/ 250*0.9 TOUCHSPEED/ 10 PREHIT/0.5 RETRACT/0.5 CHECK/0.51,1 CLEARP/ZPLUS,3.5,ZPLUS,3.5,ON MOVE/CLEARPLANE CIR_ROUGHXY1=FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<0,0,2.85>,<0,0,1>,5.49 ACTL/<0,0,2.85>,<0,0,1>,5.49 TARG/<CIR_READPNTS.X,CIR_READPNTS.Y,2.85>,<0,0,1> START ANG=0,END ANG=360 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO MOVESPEED/ 250*0.9 TOUCHSPEED/ 5 PREHIT/0.1 RETRACT/0.1 CHECK/0.11,1 CIR_B =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<0,0,2.85>,<0,0,1>,5.49 ACTL/<0,0,2.85>,<0,0,1>,5.49 TARG/<CIR_ROUGHXY1.X,CIR_ROUGHXY1.Y,2.85>,<0,0,1> START ANG=-120,END ANG=240 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO A2 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN_A ALIGNMENT/TRANS,XAXIS,CIR_B ALIGNMENT/TRANS,YAXIS,CIR_B ALIGNMENT/TRANS,ZAXIS,PLN_A ALIGNMENT/END
