Hi! We have Global Performance machine and PC-DMIS CAD++ 2014 soft. Can they be used to measure screw surface step? Maybe somwhere is instruction or samples how measure this parameter? Maybe need to update soft? Thanks for your answers!
How to measure screw surface step?
Ok, there is picture what we need to measure:
There is the link to information (Russian site, use translator) what is the screw surfaces. h - screw surface step
https://studfiles.net/preview/3675700/
Can we see the actual picture of the part? Is it like checking impeller surface, coil surface spacing, pitch, taper rate? It’s conical, right? You might be able to do away with surface points with snap on. Do you have CAD? This component is part of your killing machine to be used on MAGA country, no?
by AuRulesA friend of mine called me about 6S surface finish and I could not find anything on the internet about it, I remember it from my last job with him, but...
03-14-2011, 11:00 AM -
by RussLWe have recently been informed by our customer that they have been informed by Hexagon that there is an issue with "a step library embedded within...
02-21-2008, 07:32 AM -
by RSNICKERI'm having troble with some offline progamming and the only file I can pull in is the step file. Does one work better than the other? Can I still program...
01-24-2008, 01:24 PM -
We have a current customer that has contacted us on a project they are working on to produce their solid models they are supplying to us in a STEP AP242...
05-13-2014, 04:42 PM -
by 12345PC D-MIS CAD V4.2 MR1
XP SP3 - 2.33 GHz - 992 MB RAM
1488 MB (initial) to 2976 MB (max) paging memory
step file is less than 2 MB...-
12-08-2008, 10:19 AM -
