How to avoid points in alignment.
  • How to avoid points in alignment.
    I am working with CMM pro. I normally create alignment with cad features in CMM probe. IN fact in one program, I used manual HIt to make plane for alignment. However, the new updated piece is having curve which makes flatness out of specification. So, I need to avoid three point or HIT of the plane in -Y axis. I don't know if I can remove the Hit points or not. Can I mark it so CMM probe can skip the HIT and CMM can finish program all the way in execution.
    If it's a measured plane(versus an Autoplane) you can delete hits from it. But you need to be sure you have at least 3 hits left in the plane, more if you need flatness.
    In your case I can't tell you if this is the right thing to do, but I can tell you it can be done.
    PC-DMIS 2016.0 SP8
    Jeff
      I have moved my hits around. Especially, once I set up the part, I realize that the probe is going to hit or too close to the standoff.
      Darroll
      2018R2
        Can I delete the HIT points in manual alignment. I think I will. Still have more than six Hit after I delete the HIts. Would it be okay to delete or marked so do you think CMM would be able to finish program?
          If you have more than the required 3 hits for a plane and it's manual hits then you should be able to get away with it. The best way to find out is to do a dry run off-line.
          Darroll
          2018R2
            It means I need to skip the HIT points in manual alignment with highlighting them sky blue color, right. I didn't understand your sentence. Am I right?
              While this can be done, it will still calculate the plane based on all the hits, including the hits that weren't run. Since they weren't executed, the unmarked hits will have the same value as the last time they were run marked. This will skew the measurement of the plane.
              PC-DMIS 2016.0 SP8
              Jeff
                just highlight and delete each hit one at a time and answer question correctly after you delete each hit it is pretty easy to do
                Michael A Wildschutz Sr
                I Walk on The WildSide
                "To Each is Own"
