I have something on a print I haven't seen before. It's asking for a Profile a measurement callout. #'s 47 and 50. I'm attaching a snippet of the print. Any help would be much appreciated. Capture2640.JPG
Profile callout to distance
B is a plane around a hole not shown on the snippet. Here's another snippet showing what I'm assuming is Datum B. There is no Datum B symbol. Capture 2640-b.JPG
Originally posted by kcassaday View PostB is a plane around a hole not shown on the snippet. Here's another snippet showing what I'm assuming is Datum B. There is no Datum B symbol. Capture 2640-b.JPGLast edited by marcc; 07-12-2019, 11:16 AM.
A is a plane comprised of two 15mm diameter datum target zones (behind/beyond view) around the two holes per pic on post #4 (top hole being C datum)
Correct me if I'm wrong but A is ALSO a datum line between the plane/cylinder intersect of the 9mm diameter holes (A1 to A2 targets?) not 100% on this one. <-nope I'm wrong. A is purely two coplanar pads
B appears to be a planar datum target zone AND a point between the plane/cylinder intersect of the slot centroid. <-Nope I'm wrong B is purely the pad, D is the datum target centroid
C is the top left hole of the pic in post #4
For DIM47: I presume engineer wants DIM47 to be oriented about a common plane derived from A-B planar target zones, with the 1.5° angle. The profile is controlling only parallelism/angularity and location based on the angle from A-B common plane.
For DIM50/DIM51, it's horribly called out, but CZ = Common Zone, which means anything that resembles a relation to that distance is simultaneously controlled. Treat the CZ just like profile to an interrupted plane comprised of 4 surfaces, which has the "4 Surfaces" note beside the profile callout. It's purely angularity.Last edited by louisd; 07-12-2019, 11:35 AM.
- Likes 1
by WolfManGuys, is this a legit callout having a SR .812 +0-.002 and a unilateral profile .002 ?
They want me to measure the profile, I just think...-
05-06-2015, 03:41 PM -
by Liambo734Hi folks a bit of help needed thanks!!
1-I have scanned the profile of the cad to report the deviation for the profile callout (in box)...-
01-14-2009, 04:51 PM -
by WolfManIs this a Legit callout, to have a profile .020 (without any datum in the FCF)
and this Profile .020 -A- (where the callout is to the datum...-
04-21-2015, 09:07 AM -
by USMC81Please see attached drawing. My question is in regards to the callout labeled 13 Surface Profile of .002 AB Unilateral. My question is what surfaces are...
06-26-2012, 02:45 PM -
by GuestIs their anyone out there that can give me a good definition of both the profile and boundary and which one would be the best to use without cad ?? ...
09-30-2008, 12:53 PM -
