I am having trouble with a probe build. I have a Ceramic 30mm x 1.5mm disk, this does not show up in the drop down, I had to install an m3 to m2 adapter to it which is not in the library.. I can only find a 25mmx1.5mm disk in the drop down.
I have to use a 50mm extension with the build also My final Probe assembly is TP20, 50mm extension, M3 to M2 adapter then the 30 mm x 1.5 mm disk.Is there any way to add specific tips or adapters to the library?
