2019 Quick Features
  • 2019 Quick Features
    Have a cylindrical bore, interrupted by two opposing keyways. When using quick features, I would like to use either cylinder or circle, but holding shift only selects half of the bore, I can not get a full circular feature to detect. Is there a trick?
    Browne & Sharpe Global Advantage 12|22|10
    PCD 2012 MR1 CAD++
    YES & NO. Since the surface is interrupted by the key, you will have to type in the start/end angles to get the whole hole.
      That makes sense., Thanks!
      PCD 2012 MR1 CAD++
        Matthew D. Hoedeman Is there an issue doing this when it comes to a profile, for example? Would it be better to measure "each surface" independently and then construct a feature?
          Have you tried clicking both half's without releasing shift key?
