I"m really new to PC-DMIS. I'm having an issue with the CAD model representation disappearing from finished programs. I programmed a part Monday, and when I opened the program Tuesday, the CAD model wasn't on the screen. The program ran fine, but I couldn't figure out what happened to the CAD model. I re-programmed the part yesterday, and shut off the CMM when I left last night. This morning, I opened the program and the model was there. I ran the program to check some parts, then closed the program to work on something else. When I opened the program, the CAD model was gone. I'm not too sure what"s going on, other than the fact that it's probably something that I'm doing. Any ideas? I'm not sure I trust the program without seeing the model.
Weird CAD problem?
The program should be fine without the model. The CAD is saved in the program directory alongside the program itself. You can manually go in and delete .CAD file and nothing in the program changes.
That being said, maybe it is a bug or a permissions issue?
What version of PC-DMIS are you running (including service pack)?
Could be a few things...
1) When you use CAD in a part program it generates a .CAD file with the same name as the program, so 12345.PRG & 12345.CAD.
When you open the .PRG it looks for a .CAD file and if it's there it uses it in the program.
If you've moved or renamed the program in Windows (i.e. NOT done a File>Save as within Pc-Dmis) you will have to move/rename the .CAD also
2) Edit > Graphics Display Window > Hide & Show graphics - Model display can be switched off in thereApplications Engineer
Hexagon UK
- Likes 1
by qcfire65I have imprted a CAD model and wrote a complete program by it but when it came time to run the program later the CAD model was not there, the program...
05-02-2012, 09:45 AM -
by FCGomesOK, so I programmed a part off the CAD model.
I ran the program a couple of times, all fine, works great.
Just re-opened the program and...-
04-07-2010, 01:08 PM -
by B. Jacobs
Can someone tell me why I have lost my CAD model? I have a program that I saved and when I open it up it works fine and the Cad model is there....
04-21-2006, 10:01 AM -
by PCDEMONI replaced a cad model in an existing program (new revision) . Ran the program works ok . Problem occurs when I try to add new features
02-12-2009, 05:12 PM -
by SI_GUY_29So, Im in this program and I'm trying to bring up the Cad Model within the graphics window. The only problem is that I can't access Cad levels to insert...
10-31-2017, 10:18 AM -
