PC-DMIS 50 converter
  • PC-DMIS 50 converter
    Where does PC-DMIS select the 50 Converter at? Can I change that to CutePDF?
    Thanks,
    You would set Pcdmis to print to a printer and CutePDF is the printer.
      I believe it usually does that when you don't have a printer set as default your windows computer
      Michael A Wildschutz Sr
      I Walk on The WildSide
      "To Each is Own"
        File-> Printing-> Edit window print setup
        I'm pretty sure is where you need to go.
          go to your computer windows settings and then go to devices and then go to printers like shown in the screen capture I added select the printer you want and right click and set it as defaultprinter setup Capture.JPG
          "To Each is Own"
