Different vector when making a line and when making a point, with the tip TIP / T1A30B-135, ANGLE. Because ??? Thank you for the answers.
Different vector , with the tip TIP / T1A30B-135, ANGLE.
I would say that you selected the cad surface for the point and not for the line.
A line is a measured line is a "2d feature", if you don't select the right plane or the right surface, the cmm can't know where to project the hits !
And the tip angle has nothing to see with the vector point or line...
- 1 like
Maybe on the jogbox, you are in "probe" position, so the cmm moves along probe axes.
In this case, the line is perp to the probe. If A0B0, the line is perp to the plane and to the probe axes.
If you turn the part at 45° of cmm axes, take a point manually moving along Xaxis, the vector won't be perp to the surface.
If the feature needs a vector to be defined, the cmm can't know it if it's not defined by another way...
A CMM is not magic !
If you have CAD, use the virtual probe for measured features or use AUTO Features. With CAD, you don't need to drive the CMM manually create features. Its an inefficient waste of time. By creating a program this way, you need to fix vectors and change all kinds of feature nominals. By using the CAD you are creating a program to check a nominal part, by using an actual part, you are creating a program to check that "specific part" with all its flaws included.
Originally posted by Schlag View PostIf you have CAD, use the virtual probe for measured features or use AUTO Features. With CAD, you don't need to drive the CMM manually create features. Its an inefficient waste of time. By creating a program this way, you need to fix vectors and change all kinds of feature nominals. By using the CAD you are creating a program to check a nominal part, by using an actual part, you are creating a program to check that "specific part" with all its flaws included.sigpic
OH, I HAVE cad, but only for the PART, I never get cad for the fixture (1 time out of 300 or so I might get fixture cad, but it usually isn't an exact match to the physical fixture)sigpic
by Darius11Hi,
I am trying to get A angle of tip for script.
From help:
"Tip.A
Returns the A angle of the tip. Read-only...-
Channel: PC-DMIS Code Samples
07-27-2020, 07:31 AM -
by rbexplorerHallo everybody,
I have one question, what does SHANKIJK=0, 0, 1, ANGLE=90 in row TIP/T1A0B0... mean, please?
Thank you...-
05-28-2009, 11:19 AM -
by edrakeOK, I'm getting a little confused by what's going on with the shank vector/angle info in a given tip change.
Quick bit of background: We...-
02-05-2014, 01:14 PM -
by WolfManHood morning fellas, I have a problem
I want to create an L-shape probe, I only need 1 probe at A90B180, no others is that doable or do...-
02-26-2014, 08:51 AM -
by UnderspecSay I have a tip rotation in the code and a move point somewhere after that. I create a marked set which does not use the tip rotation. I'm seeing that...
08-29-2007, 10:47 AM -
