**ISSUE FIXED, SEE COMMENT #2**
__________________________________________________ __________________________________________________ ____________________________________
Original Post:
Hi All,
Using PC DMIS CAD 2019 R1....
How do I properly find this breakout point? Its the intersection of the top plane & the ID RAD 0.125.
Currently, I have the line (pretty straight forward) and I have the arc (measured using FIXED RAD PC DMIS small arc method). The vectors of my features are pointing at one another and I am in an appropriate workplane.
My overall goal:
Find this point...and then.. "copy & paste with pattern" that code & then construct the points into a CIR_97. I know how to work with pattern-ing...just not how to get the actual point.
Heres what I have so far:
Original Post:
Hi All,
My overall goal:
WORKPLANE/YMINUS MOVE/CLEARPLANE PNT43 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<0.81,0,0>,<0,0,1> ACTL/<0.81,0,0>,<0,0,1> TARG/<0.81,0,0>,<0,0,1> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO PNT44 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<0.775,0,0>,<0,0,1> ACTL/<0.775,0,0>,<0,0,1> TARG/<0.775,0,0>,<0,0,1> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO LIN4 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0.81,0,0>,<-1,0,0> ACTL/<0.81,0,0>,<-1,0,0> CONSTR/LINE,BF,2D,PNT43,PNT44,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 MOVE/CLEARPLANE CIR4 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,FIXED_RAD THEO/<0.8025,0,-0.1176>,<0,-1,0>,0.25,0 ACTL/<0.8025,0,-0.1176>,<0,-1,0>,0.25,0 TARG/<0.8025,0,-0.1176>,<0,-1,0> START ANG=170,END ANG=120 ANGLE VEC=<1,0,0> DIRECTION=CW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO A8 =ALIGNMENT/START,RECALL:A5,LIST=YES ALIGNMENT/TRANS,XAXIS,CIR4 ALIGNMENT/TRANS,ZAXIS,CIR4 ALIGNMENT/END MOVE/CLEARPLANE RAD_66_1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,0>,<0,-1,0>,0.25,0 ACTL/<0,0,0>,<0,-1,0>,0.25,0 TARG/<0,0,0>,<0,-1,0> START ANG=175,END ANG=115 ANGLE VEC=<1,0,0> DIRECTION=CW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO RECALL/ALIGNMENT,INTERNAL,A5
