Hey all Hope its going well for everyone.
I'm having an issue where the probe keeps "crashing" when I try to measure a hole. The "crash" happens right in between my manual alignment and my first DCC alignment. I am leveling to a plane, creating a line from 2 circles, and then I the plane, the line and one of the circles to lock all my translates down.
Then when it switches to DCC, measures the plane again and then come to measure to hole and hits the side of the hole.
When I put my cursor above A1 all of my features line up correctly on the screen, then when I place the cursor below A1 all of my features move. See Pictures 1 and 2.
This originally happened in a program I wrote offline, eventually I said screw it and just rewrote the whole program Online and it did the same thing.
Above A1
Below A1
Thanks in advance for any help.
MAN_PNT_1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-7.2554,6.4032,-0.0167>,<0.0000002,-0.0030104,0.9999955> ACTL/<18.8641,17.8721,-29.2933>,<-0.0604878,0.0485539,0.9969873> TARG/<-7.2554,6.4032,-0.0167>,<0.0000002,-0.0030104,0.9999955> SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO MAN_PNT_2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-7.1767,2.115,-0.0296>,<0.0000002,-0.0030104,0.9999955> ACTL/<18.8982,13.6825,-29.2931>,<-0.0637221,0.0601004,0.9961563> TARG/<-7.1767,2.115,-0.0296>,<0.0000002,-0.0030104,0.9999955> SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO MAN_PNT_3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-13.9166,2.0709,-0.0298>,<0.0000002,-0.0030104,0.9999955> ACTL/<12.2408,13.6838,-29.2922>,<-0.0770604,0.037707,0.9963131> TARG/<-13.9166,2.0709,-0.0298>,<0.0000002,-0.0030104,0.9999955> SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO MAN_PNT_4 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-14.049,6.3862,-0.0168>,<0.0000002,-0.0030104,0.9999955> ACTL/<12.2418,17.8971,-29.2923>,<-0.0945211,0.0339304,0.9949445> TARG/<-14.049,6.3862,-0.0168>,<0.0000002,-0.0030104,0.9999955> SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO MAN_PLN_1 =FEAT/PLANE,CARTESIAN,OUTLINE,NO THEO/<-10.5994,4.2438,-0.0232>,<0.0000002,-0.0030104,0.9999955> ACTL/<15.5612,15.7839,-29.2927>,<0.0001392,0.0000458,1> CONSTR/PLANE,BF,MAN_PNT_1,MAN_PNT_2,MAN_PNT_3,MAN_PNT_4,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 MAN_CIR_C =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<0,0,0>,<0.0000002,-0.0030104,0.9999955>,0.252 ACTL/<26.2839,11.5222,0.0347>,<0.0000002,-0.0030104,0.9999955>,0.2524 TARG/<0,0,0>,<0.0000002,-0.0030104,0.9999955> START ANG=0,END ANG=-360 ANGLE VEC=<-1,0,0.0000002> DIRECTION=CW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=4,DEPTH=0.04,PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=0.3937 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=NO MAN_CIR_2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<-21.326,0,0>,<0.0000002,-0.0030104,0.9999955>,0.252 ACTL/<4.9573,11.5353,0.0347>,<0.0000002,-0.0030104,0.9999955>,0.252 TARG/<-21.326,0,0>,<0.0000002,-0.0030104,0.9999955> START ANG=0,END ANG=360 ANGLE VEC=<1,0,-0.0000002> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=7,DEPTH=0.04,PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=0.3937 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=NO LIN1 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0,0,0>,<-1,0,0.0000002> ACTL/<26.2839,11.5222,0.0347>,<-0.9999998,0.0006142,0.0000021> CONSTR/LINE,BF,3D,MAN_CIR_C,MAN_CIR_2,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 A1 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZPLUS,MAN_PLN_1 ALIGNMENT/ROTATE,XMINUS,TO,LIN1,ABOUT,ZPLUS ALIGNMENT/TRANS,ZAXIS,MAN_PLN_1 ALIGNMENT/TRANS,YAXIS,LIN1 ALIGNMENT/TRANS,XAXIS,MAN_CIR_C ALIGNMENT/END GOTO/MENU RUN_DCC_ALIGNMENT=LABEL/ MODE/DCC CLEARP/ZPLUS,2,ZPLUS,2,ON MOVE/CLEARPLANE DCC_PNT_1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-4.0957,6.3534,0>,<0,0,1> ACTL/<-4.0957,6.3534,-0.0007>,<0,0,1> TARG/<-4.0957,6.3534,0>,<0,0,1> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO MOVE/CLEARPLANE DCC_PNT_2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-3.9045,2.1719,0>,<0,0,1> ACTL/<-3.9046,2.1719,-0.0007>,<0,0,1> TARG/<-3.9045,2.1719,0>,<0,0,1> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO MOVE/CLEARPLANE DCC_PNT_3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-17.3028,1.9728,0>,<0,0,1> ACTL/<-17.3029,1.9728,-0.0008>,<0,0,1> TARG/<-17.3028,1.9728,0>,<0,0,1> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO MOVE/CLEARPLANE DCC_PNT_4 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-17.5543,6.3488,0>,<0,0,1> ACTL/<-17.5544,6.3488,-0.001>,<0,0,1> TARG/<-17.5543,6.3488,0>,<0,0,1> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO DCC_PLN_1 =FEAT/PLANE,CARTESIAN,OUTLINE,NO THEO/<-10.7143,4.2117,0>,<0,0,1> ACTL/<-10.7144,4.2117,-0.0008>,<-0.0000215,0.0000448,1> CONSTR/PLANE,HIPNT,DCC_PNT_1,DCC_PNT_2,DCC_PNT_3,DCC_PNT_4,, MOVE/CLEARPLANE DCC_CIR_1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<-21.326,0.0004,0.036>,<0,0,1>,0.252 ACTL/<-21.326,0.0004,0.036>,<0,0,1>,0.252 TARG/<-21.326,0.0004,0.036>,<0,0,1> START ANG=0,END ANG=-360 ANGLE VEC=<-1,0.0000207,0> DIRECTION=CW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=7,DEPTH=0.04,PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=0.3937 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=NO MOVE/CLEARPLANE DCC_CIR_2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<0,0,0>,<0,0,1>,0.252 ACTL/<-26.2768,-11.5383,29.2538>,<-0.0001371,-0.0030563,0.9999953>,0.252 TARG/<0,0,0>,<0,0,1> START ANG=0,END ANG=360 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=7,DEPTH=0,PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=0.3937 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=NO LIN2 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0,0,0>,<-0.9999986,0.0000207,0.0016881> ACTL/<-26.2768,-11.5383,29.2538>,<-0.9999986,-0.0005987,0.0015492> CONSTR/LINE,BF,3D,DCC_CIR_2,DCC_CIR_1,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 A2 =ALIGNMENT/START,RECALL:A1,LIST=YES ALIGNMENT/LEVEL,ZPLUS,DCC_PLN_1 ALIGNMENT/ROTATE,XMINUS,TO,LIN2,ABOUT,ZPLUS ALIGNMENT/TRANS,ZAXIS,DCC_PLN_1 ALIGNMENT/TRANS,YAXIS,LIN2 ALIGNMENT/TRANS,XAXIS,DCC_CIR_1 ALIGNMENT/END
Below A1
