Get measured dimension inside loop command
  • Get measured dimension inside loop command
    Does anyone know who to extract measured dimensions inside a loop command for repeating features using API? Thanks.
    Originally posted by cmshieh View Post
    Does anyone know who to extract measured dimensions inside a loop mcdvoice command for repeating features using API? Thanks.
    here i wanted to ask the same
      I presume you are talking about something like this?
      assign/v1=dimension1[1].x.meas
      cycle the bracket value for each array index
      you could even do something like this
      assign/count=1
      do
      assign/v1=dimension1[count].x.meas
      assign/count=count+1
      until/count==loopcount(whatever your number is)
      what do you plan to do with the values? you could report them within the loop and not have to extract later, that would be cleaner in my opinion.
        The code looks something like this:
        [FONT=courier new]LOOP/START,ID=YES,NUMBER=TUBE_COUNT,START=1,SKIP=,OFFSET:XAXIS=0,YAXIS=0,ZAXIS=0,ANGLE=0
            DIM D29_D30_= POSITION OF CYLINDER FEATURE_CYL_29  USE AXIS=WORST (START PT)  REF LENGTH=0.0000  UNITS=IN ,$
            GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH  FIT TO DATUMS=OFF  DEV PERPEN CENTERLINE=OFF  DISPLAY=DIAMETER
            AX    NOMINAL       +TOL       -TOL      BONUS       MEAS        DEV     OUTTOL
            Y      0.0000                                      0.0000     0.0000
            Z      0.0000                                      0.0000     0.0000
            DF     0.5180     0.0020     0.0010                0.5180     0.0000     0.0000 -----#------------
            TP        RFS     0.0050                0.0000     0.0000     0.0000     0.0000 #-----------------
            END OF DIMENSION D29_D30_
        LOOP/END[/FONT]
        The intention is to extract the data automatically after running the PC-DMIS program to be uploaded into an in-house database using an automation tool. After some trial-and-error, looks like turning PREVIOUS_RUNS from DELETE_INSTANCES to KEEP_INSTANCES in PRINT/REPORT will do the trick.
          DIM D29_D30_= POSITION OF CYLINDER FEATURE_CYL_29[B][loop id] [/B]USE AXIS=WORST (START PT) REF LENGTH=0.0000 UNITS=IN ,$
          LOOP/END[/FONT]
          would work.
          also, you could use different modes of data output than print/report. --If you are looking to output the measured values exclusively, you can use two other methods:
          This will output a report with ONLY the measured data of each looped dimension output.
          assign/count=1
          do
          assign/v1=[B]DIM D29_D30_[count].Diam.meas [/B]
          [B]comment/report= DIM D29_D30_[count].Diam.meas [/B](or V1, or whatever assignment you want to define for your measured value)
          or you can completely avoid the print report command and specify a *.CSV file with assignments, then do file/writeline to output the measured value directly into a csv file. Every time routine runs, it appends the data to bottom of CSV. This is what we use.
          Here's an example:
          [B]Beginning of routine[/B]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_PATH[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"C:\PRODUCTION\parts.CSV"[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]PART[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"PARTNUMBER"[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]ROUTINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"PARTNUMBER CMM"[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]TRACE_FOLDER[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"Traceability-customer CMM"[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]CHAR_1[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"AA #3 Position "[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]CHAR_2[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"AB #5 Position "[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]CHAR_3[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"AD #7 Position "[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]CHAR_4[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"AD #8 Position "[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]CHAR_5[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"AE #18 Position "[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]CHAR_6[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"AF #39 Position "[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]CHAR_7[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"AG #92 Position "[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]ASSIGN/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]CHAR_8[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"AH #93 Position "[/SIZE][/FONT][/SIZE][/FONT]
          [B]Before loop:[/B]
          [FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE [/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]=FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]OPEN[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_PATH[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]APPEND[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/PART NUMBER/" + "," + PART[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/ROUTINE NAME/" + "," + ROUTINE[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/LOT#/" + "," + RUN_ID[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/OPERATOR/" + "," + TRACE_FOLDER + "," + "Operator" + "," + OPERATOR[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/SCHEDULED TIME/" + "," + TRACE_FOLDER + "," + "Scheduled Time" + "," + TIME[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]CLOSE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]KEEP[/SIZE][/FONT][/SIZE][/FONT]
          [B]At end of looped segment, so the data outputs each time a part is measured (V1 is Loop ID)[/B]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/CAVITY ID/" + "," + TRACE_FOLDER + "," + "Position " + V1 + "," + POS[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/DATA/" + "," + CHAR_1 + V1 + "," + DIST_AA_1.MEAS[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/DATA/" + "," + CHAR_2 + V1 + "," + DIST_AB_1.D.MEAS[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/DATA/" + "," + CHAR_3 + V1 + "," + DIST_AD1_1.MEAS[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/DATA/" + "," + CHAR_4 + V1 + "," + DIST_AD2_1.MEAS[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/DATA/" + "," + CHAR_5 + V1 + "," + DIST_AE_1.MEAS[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/DATA/" + "," + CHAR_6 + V1 + "," + DIST_AF_1.D.MEAS[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/DATA/" + "," + CHAR_7 + V1 + "," + DIST_AG_1.MEAS[/SIZE][/FONT][/SIZE][/FONT]
          [FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF]FILE/[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]WRITELINE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]C_FILE[/SIZE][/FONT][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF][FONT=CourierNew][SIZE=8px][COLOR=#0000FF],[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=CourierNew][SIZE=8px][FONT=CourierNew][SIZE=8px]"/DATA/" + "," + CHAR_8 + V1 + "," + DIST_AH_1.MEAS[/SIZE][/FONT][/SIZE][/FONT]
