Hello everyone im having this issue with my CMM its a Brown & Sharpe Xcel with a Sharp32 controller, the error that im having its DDOF: Waiting For In Position, what happens its when i calibrate my tips and it starts the DCC move on the Z axis touches the sphere and it stays there it wont retract an then it sends me this error, the machine was working just fine it all started after i removed the TP20 to replace it for a new one, i put the new one in place and started calibrating the tips first manually to locate the sphere everithing normal until it starts the DCC move, it does the same with the 2 TP20 that i have and also with different Modules does the same thing, the machine moves soft on the 3 axes manually and with the joystick, i have another CMM a Wenzel with Pc Dmis also and on that machine everything works the 2 TP20 , the modules, i also replace the autojoint for a new one but the same problem so all the components work jus fine, when i touch the probe with my hand or anything else it works it detects the touch but in DCC its when i have this issue, i hope you guys can give some hints about what could be happenning, sorry my english its not the best.
DDOF: Waiting For In Position help!!!
Double check and make sure your Calibration Ball is correct. Doesn't hurt to make sure. If that's all good, see if Reset tips to theo is checked, Oh and make sure your probes are on straight. If all else fails, ReBoot(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
- Likes 1
Originally posted by KIRBSTER269 View PostDouble check and make sure your Calibration Ball is correct. Doesn't hurt to make sure. If that's all good, see if Reset tips to theo is checked, Oh and make sure your probes are on straight. If all else fails, ReBoot
- Likes 1
by tjackson2So, I come in this morning to an email from our 2nd shift operator, one of our probes fitted with an EM2 module will not register hits at all. He used...
11-15-2012, 08:46 AM -
by CptNemoI am trying to calibrate a probe angle of A105 B180 and keep getting a TR_OUTOL, Machine Parameter Out of tolerance error. All the other probes calibrate...
06-14-2010, 07:40 AM -
by mrogers95129I start with a 1.5 X 30 MM probe. I probe A0B0 and A90B90 and A90B-90. I return to the A0B0 position and measure the calibration sphere again and assign...
03-27-2014, 07:58 PM -
by Axel45I am using a PH10T with a Tp-20. I have decided to add a 100mm extension to all of my probe files. Now They wont auto calibrate correctly. When they...
08-14-2006, 12:17 PM -
by ImpelDanHaving an issue that I have never seen before with a machine. (PH10MQ, PH20-NI)
The probe will contact the surface, audible beep will sound, and...-
12-21-2017, 04:25 PM -
