Experts advise required
I am doing a Gage R&R in a part using CMM, which has internal taper profile.The angle is failing in the Gage R&R again and again. All other characters are passing in the same part.
Could any one give some clue to create a perfect auto cone feature. Below is the parameters currently I am using. Any help would be greatly appreciated.
Cone angle 12 degree total tol 0.084
Cone height 3.8 mm
Diameter 60 mm
Parameter
Total points - 3 rows X 9 points= 27
Touch speed 1mm
Azimuth angle 0 to 360 degree
Touch Probe 3X20 ruby ball
Probe module TP20
PH10T
Sekhar
Cone height 3.8 mm
Diameter 60 mm
Parameter
Touch speed 1mm
Probe module TP20
PH10T
Sekhar
