Recall Alignment
  • Recall Alignment
    When I type recall an alignment and this's what my edit window shows: RECALL/ALIGNMENT,INTERNAL,A27:INTERNAL
    From drop down list: RECALL/ALIGNMENT,INTERNAL,A27
    What's the difference and why
    v2013
    When I type "REC" PC-DMIS autocompletes "RECALL". When I press tab I get the following:
                RECALL/ALIGNMENT,INTERNAL,ALN8
    I looked in the help file and there is no mention of anything after a colon for the Recall command. When I tried to put ":INTERNAL" at the end of the recall command PC-DMIS froze up.
    Sorry, but I have no idea what's going on.
    PC-DMIS 2016.0 SP8
    Jeff
      v2013
      Nothing.
      I don't fully understand it either but it appeared around 2012 I believe where they added the USE_PART_SETUP option in the Recall alignment section of the Alignment dialog.
      Applications Engineer
      Hexagon UK
        I have had issues with alignments that have this automatically added to the recall alignment. I usually delete the (:INTERNAL) from the recall alignment. I haven't had a chance to do more testing to find out if this was the real issue of the affected routines. After removing the (:INTERNAL) from the recall alignment the alignment issue would be corrected.
          Actually, I didn't type the whole thing. With current alignment, I typed "recall/alignment" then hit "enter". The reason I did this is to add more features and alignments above it and not change anything below it by accident
            I'm guessing that the extra INTERNAL tells it to recall the previous recall/alignment,interal,ABC not the original ABC alignment. I'm not sure if it has any impact, I always delete the extra internal at the end.
