Good day everyone, I have a problem with legacy reporting in that at times when PC-DMIS outputs to PDF the CAD is suddenly zoomed out, making it difficult to read the report i.e leader lines mashed up etc. Does anyone know how this can be fixed?
Legacy Reporting Glitch
Hi Mike, should the CAD on the report page also change its orientation? When I rotate and make a viewset then recall before the alignment dimension, for example, then open the alignment page, the CAD is still the same orientation as when I first rotated it in the page itself.
When I use viewsets, whichever viewset I currently have recalled is how it looks in my report. I turn CADGRAPH/ON in the dimension I want arrows displayed for and use Insert> Report Command> Screen Capture right after the Recall/Viewset command. This forces it to use the orientation/zoom of what is currently displayed in the Graphics Display Window on the report. If I need different views, then I have different viewsets, recalled before the appropriate dimensions. I believe if you turn on specific ID labels when you create a viewset those will also display in the same orientation/location every time too
Recall Viewset Align (Before Report).JPGI also tried recalling before the page. As far as I understood only custom reports used view sets to determine the CAD orientation in the page. Legacy reports have their own CAD window in the page to set up the view.
by Paul SarrachI know I just went thru this but cannot find the post. I have 2011 and I want a legacy report. I already have the dimensions in legacy but what do...
10-03-2011, 06:20 PM -
by NinjaBadgerAnyone got the link to Wes' Xact Measure reporting post/information synopsis thing?
Ta.-
05-07-2019, 11:07 AM -
by ktannerIs there a way that I can change my report mode in 4.2 back to my normal reports of 3.7? I dont like the new reporting function.
10-05-2007, 09:41 AM -
Just started with 4.2 MR1 and not up to speed with the new reporting. Can one access the old reporting for the time being? If so how?
Thanks...-
03-20-2008, 11:58 AM -
by m.gomezThis is just me testing the climate of CMM users preferences:
I have been using PC DMIS for close to 3 years and have been taught from...-
02-25-2014, 09:18 AM -
