Hi all,
I've set up a program launcher and subroutine and set it to run up to 8 parts. It's a critical progam and we are subject to run it 100% so I'm trying to save time. It all works fine but I am trying to automate the answers so that the program doesn't stop for any input at the end of each run.
For the criticals the customer wants a simple yes or no supplied on the report, as you can see the dimension SHT2D2_0_505_Z I have set to register if out of tolerance, is there a way to answer yes in the following comment if in tolerance, and no if not using variable to take away the manual interevention?
Thanks in advance
Thanks in advance
