2019 r1 sp3
And here is the release note :
Release Notes - 2019 R1SP3
• PCD-100898 - Fixed an issue where specific manual measured contact slot
features did not completely execute.
• PCD-107474 - Fixed an issue where the Initialize Probe button on View |
Other Windows | Probe Toolbox failed to connect to or disconnect from
the T-Scan 5 T-Collect interface.
• PCD-149319 - Fixed an issue where the Text and CAD template
(TEXTANDCAD.RTP) was broken because the SIMUL_LABEL.LBL file was
missing from the installer.
• PCD-157075 - Fixed a crash that occurred when the Status window was
enlarged greater than the Graphic Display window with a Pointcloud Surface
Colormap scale.
• PCD-158397 - Added the Use Offline Help menu item on the Help menu
where you can choose to use the offline installed Help rather than use the
online Help.
• PCD-158609 - Added support for the DEVA 037 Manual Counter Card. You
need to install the DEVA driver to install all DEVA card related files. To use
this interface, you must rename the following files:
MANUALCMM.DLL to INTERFAC.DLL
GMS_for_Deva_EncLib.XML to GMS.XML
• PCD-158695 - Fixed an issue that prevented feature items from appearing in
the feature list of the XactMeasure GD&T dialog box.
• PCD-161245 - Fixed an issue where Thickness Scan and Thickness Gage
showed all previous hidden labels in the CAD window when you clicked
Create or OK.
• PCD-161246 - Changes to the nominal values and tolerances of a dimension
for a Point of Interest (POI) in the Thickness Gage command are now
retained.
• PCD-161249 - Fixed an issue where the POIs from the Thickness Gage were
not reported properly relative to an alignment that differed from the CAD
alignment.
• PCD-161250 - Fixed an issue with incorrect thickness gage Point-of-Interest
(POI) locations after alignments.
• PCD-163357 - Fixed an issue where the execution of specific laser commands
caused an application error.
• PCD-163823 - Fixed an issue where the Done button on the jog box did not
work when both arms executed a manual feature in a dual-arm
measurement routine.
• PCD-165061 - Fixed an issue in the mirror operation that could result in an
application error.
• PCD-165205 - Fixed an issue where the bonus value in lower-segments of
composite position callouts were not shown properly when the input
features had no similar vectors.
• PCD-165295 - Updated to the CMS Toolkit to version 7.40 to improve the
calibration process.
• PCD-165335 - Fixed an issue where a comma was missing in the Xact
Measure command to separate options.
• PCD-165488 - Fixed an issue where licensing registry searches didn't properly
check whether the HASP license existed or not.
• PCD-165512 - Fixed a crash that occurred for a Feature Control Frame
Position when 192 or more features were selected.
• PCD-165636 - Fixed an issue where the outlier filter didn't always properly
filter Vision Line features if those features were in a subroutine.
• PCD-166030 - Fixed an issue with the Leica AT901 Tracker where the machine
connection and target recognition were both okay, but it would not take hits.
• PCD-167888 - Fixed an issue where there was a noticeable delay in laser
scans with a large number of points.
- 3 likes
• PCD-165636 - Fixed an issue where the outlier filter didn't always properlyfilter Vision Line features if those features were in a subroutine.
PCD-158397 - Added the Use Offline Help menu item on the Help menu where you can choose to use the offline installed Help rather than use the online Help.
I certainly like that bell/whistle. Thank you Jared & PC-DMIS Help team.
Still waiting tho, for the Vision Gage creating anything smaller than .001 (Imperial) It still doesn't work in 2019 R2 build# 033 either. I asked a few releases ago.
Oh well... I realize I was asking to reinvent the atom-smasher....
*** as of 6/26/19 there are 3 flavors of the Sp3/x64 release. I downloaded the 14.1.406.0 version (at least the package isn't ticking.....)Last edited by sealevel; 06-26-2019, 07:52 PM.
PC-DMIS CAD++ 2o19 R1 SP11
by JEFMANCan you find your happyness ?
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...1/Release/x64/
http://software.hexagonmi.co...-
02-26-2020, 10:15 AM -
by JEFMANHere :
http://software.hexagonmi.com/public...2/Release/x64/
http://software.hexagonmi.com/public/PC-DMIS-Ve...-
09-09-2020, 11:01 AM -
by JEFMANhere :
https://www.wilcoxassoc.com/public/P...18_R2/SP7/x64/
or here (#460 !):
ftp://ftp.wilcoxassoc.com/PC-...-
06-13-2019, 04:28 PM -
by JEFMANhttp://software.hexagonmi.com/public...19_R2/SP7/x64/
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve.../2019_R2/SP7/x...-
06-23-2020, 06:48 AM -
by JEFMANHave a nice reading
http://software.hexagonmi.com/public...19_R2/SP4/x64/
ftp://ftp.wilcoxassoc.com/PC-DMIS-V...-
03-16-2020, 10:09 AM -
