A while back we had one of the guys from Hexagon come in to calibrate one of our CMM's. He changed something in the configuration so that now whenever you take your manual hits on the part, the probe automatically retracts a little bit after taking your hit. How can I configure our other CMM's to do this as well?
Automatic retraction after taking hits
i believe what you're looking for is the MANRETRACT setting
setup options > part/machine tab > maunal hit retract (top right)
https://www.pcdmisforum.com/forum/pc...3-auto-retract
- 2 likes
Some controller supports it, some don’t, the one that supports it can be turned on from FDC panel and the manual re-track value is fixed meaning user manual re-track in PCDMIS can’t override it. Some can only be turn on in settings editor, the value can be anything you want once it’s on.
This will work the same take a regular Z hit as well as in a small bore correct ? So in a small bore / slot / pocket... it will manual retract and have collision ( yes minor ....) on the opposite side of the feature ? Sure its great in Z but maybe not what you want full time. Careful what you ask for ???
yes. Everything above. But since I got confused from above, as well!..... the MANRETRACT for ME did just that (for an Optiv 4.4.3 but with an Image/Advantage? I didn't mess with it) .
I think around 2010-2013 in DCC if I forgot to do safe $hit in a small CYL or CIR, the Demon took care of it. BUT.... I always taught my self the habit of always placing a Prehit/Retract (value of same n' safe) in Edit Window before sending the probe in da ho'
I must tell you a Leitz Probe and manual hits before DCC can be extremely FUSSY. I guess those Mycrona folks left some Easter eggs inside Optiv before the Hex sucked in their product!!
- 2 likes
Word of caution on manual retract option.
If you use a manual point(s) to start the program and you sneek up on the part it can read the vector direction wrong, and instead of moving away from the part it will try to drive thru the part. Not good.
So train everyone to ensure that there is enough travel (movement) on the scale so it reads the vector right.
At my last job everyone was trained to position probe where you want then raise it up then take your point.
where i'm at now it is turned off.Last edited by William Johnson; 06-25-2019, 12:06 PM.Time for the Trolls to leave.
What value is supposed to be in the MANRETRACT setting? Is this value the distance?
Originally posted by mckenzie View Posti believe what you're looking for is the MANRETRACT setting
Its in the settings editor under parameters. Or just search ManHitRetract. Set the value from 0 to 1 and your manual hits will "bounce" off the part, but like Schlag said, it will come off the surface, so if you're ever aligning to a tight hole, you will hit the opposing side.I'm neeeewwwwwwww!!!
by RennfahrHi Guys.
can someone tell me for PC-DMIS 2010, how to change hit retracts when taking manual hitsinside of small holes? I have made a grip of settings...-
12-02-2010, 06:27 PM -
by 12345BS Global 12.22.10
V3.7 MR2
XP SP2
I take manual hits, probe must be manually retracted.
I don't remember seeing this before...-
11-17-2008, 07:03 PM -
by hammerwe just had our machines recalibrated and now 1 of them is doing a automatic retract after every manual hit how do I turn this off
07-12-2016, 02:38 PM -
by Ken8282After I take a manual hit with the probe it moves in the Z minus and Y minus. It has never done this till today. The probe does not drift when left alone....
05-09-2013, 12:18 PM -
by JlaeppleDuring manual hits the probe is not retracting once contact is made, I have to manually move the "Z" plus! Is there a setting to change and...
04-01-2010, 02:38 PM -
