I have a 4 way star probe. All tips same size and oriented in common X and Y axes. Simply put. Can I use the auto feature function and then measure the OD while the star probe automatically switches to each relevant tip for the hits? As of now, I am taking points, manually dictating each tip and then constructing a circle later. Is there a better way?
star probe auto feature OD circle possible?
I've heard (but never looked) that at some point, at some version of Pcdmis, they added the ability to insert MOVE points in an autofeature circle, but I don't know if you can also add a tip change.sigpic
Originally posted by Matthew D. Hoedeman View PostI've heard (but never looked) that at some point, at some version of Pcdmis, they added the ability to insert MOVE points in an autofeature circle, but I don't know if you can also add a tip change.
I prefer the vector points method.
By using the center of the OD to allow the use of Copy/Paste with pattern around the circle. Insert moves and probe changes needed before executing, then construct circle.sigpicIt's corona time!
- 2 likes
This will ensure each point is compensated with the data from the correct tip.PC-DMIS 2016.0 SP8
Jeff
- 1 like
by trevconbjI am new to both PC-DEMIS and this forum and would greatly appreciate your help with some probe trouble I'm having.....I've built up a new probe in pc-demis...
01-24-2013, 06:58 PM -
by LondonjrWhen I attempt to use auto circle to measure a circle with a star probe. The probe crashes into the part. I am unsure what I am doing wrong herer...
03-31-2016, 04:10 PM -
by DmisDaveCan I use a star probe (4 horizontal tips) in auto features to check a bore without manually selecting each tip?
I can change the probe...-
01-26-2012, 09:55 AM -
by vraju2334Hi
is it possible to use a star probe to measure a circle using autocircle feature.if possible can anyone please help me
thank you...-
11-10-2020, 06:45 PM -
by NMC_CMMHey all,
I'm getting ready to use a star probe on our TP-200 machine and I was curious to know how PC-Dmis selects which point of the star...-
05-21-2012, 05:30 PM -
