I have a round part with a 3.5" through bore that leads into a 12" radius. That radius blends into a 10" sphere with a 0.125" radial transition from the large radius to the sphere. Everything is centered about the bore. I only have about 1" of the spherical surface on the part. The start angle is 50 and end angle is 65. I do have a model. The drawing calls out the 4" diameter where the spherical surface intersects the 0.125" blended radius. It also calls out the intersection of the 12" radius with the 3.5" thru bore. I have tried several different things but I'm not confident in any of my methods. Any suggestions or help would be greatly appreciated!!!!
Intersection of a Sphere and Radius
I'm kinda take a shot in the dark here, maybe you take single hits lets say of the sphere in let's say the same X origin and the same with the radius and make a constructed curve and intersect them? I think if you can post a pic. Would get better answer, maybe not from me but from some one else?(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
- 1 like
Here's a crude sketch.Attached Files153010 Global Advantage w/ LSPX1H_T Analog Probe
7107 Global Classic TP20
2019R1 SP1 CAD++
I would use 3 times the small arc method (12'', 0125 and 10), in different planes around the part, then construct each interset point and constuct the dimensions...
- 3 likes
"Small arc method" being per Hexagon Tech sheet PDF linked below. You'll need to sign into hexagon support to read it.Hexagon Manufacturing Intelligence’s online support centre, offering a range of services including access to our knowledge base, articles on tips & tricks, software downloads and much more.
- 2 likes
by quality2214I currently have (for a lack of better term) bowl shaped cavity that we will be injection molding into. There are no tooling prints for it. The engineering...
11-16-2006, 11:01 AM -
by UnderspecImagine a flat surface with a round indention in it. The feature looks like a sphere could sit in it. Anyway, the print calls out a radius on it. How...
05-12-2006, 02:56 PM -
by chainfeedI have a part here that is approx 4 x 4 square titanium plate with a 81.673 radius sphere. How would you guys go about checking the radius of the center...
03-03-2010, 07:22 AM -
by bob mappesI'm trying to get a depth where a spherical radius and a cylinder intersect
imagine a part, round stock, with a bore down the middle and...-
06-07-2006, 12:29 PM -
by JLHUTTHelp, I have a part that is about 3.5" long (round) with an I.D of 1.5" in diameter. On one end of the I.D. there is a radius of 1.5",...
01-03-2008, 08:14 AM -
