Hi, all. I am having trouble calibrating my star probe. It is a 5 WAY but I do not have a probe on the bottom (A0B0). I left tip #1 empty when building this setup. Slots 2-5 are filled each with 1BY10mm probes. All 4 probes are in the X and Y axes. I have a different probe that acts as the master, fyi. I have calibrated/built star probes before but they always had a probe on the bottom (A0B0). Using Manual + DCC the sofware wants me to take a manual hit in A0B0, usually this is not a problem but now I have no probe on the bottom. It also flips the first tip on its side (incorrect workplane). Am I missing something simple? Thanks for your help!
star probe calibration issue
Unless you built it wrong, Your first Tip 1A0B0 would be at 3:00, 2A0B0 12:00, 3A0B0 9:00, and 4A0B0 would be at 6:00. Also if your Probe is built correctly, The top of the Sphere becomes the side.
Capture1.JPG(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
- Likes 1
If you have another probe set as the Master and you've built the probe correctly, you should be able to simply answer No the sphere hasn't moved and use DCC+DCC like JEFMAN said.PC-DMIS 2016.0 SP8
Jeff
- Likes 3
KIRBSTER269 : Yes, I'm a robot, but a civilized one : happy week-end, all, it's friday !
And happy week-end also to all other robots here...
- Likes 4
by SluggerHey guys, not new to CMM's, just star probes. I had to run a program that had a star probe in it, so upon calibrating it I ran into issues. The probe...
09-13-2015, 12:50 PM -
by Scott BrownHello Everyone
We are currently planning to use a star probe to access holes on the bottom side of a part. Our plan is to measure all top...-
12-12-2014, 08:14 AM -
by jennyHello, I am building a star probe, here is my build, once calibrating this, I then check and my data -1.4mm off. Is this because I have the wrong exten...
07-10-2012, 03:21 PM -
by SkullbusterPCDMIS 2019 R1 on a SF CMM 4.5.4.
I am having terrible issues trying to calibrate this star probe. It is the only probe for this cmm. I am using...-
09-24-2019, 09:49 AM -
by MsolitoThe Star Probe only want to Calibrate at manual alignment (when I start in DCC or DCC+ manual stop at .500' in the side of Calibration Ball no message...
09-03-2009, 12:14 PM -
