I know this has been discussed at length on this forum and I have read most of the post. I just wanted to share what I have learned about the two, whether I am right or wrong I wanted the opinion of others.
Just a little history I work for a global company that have many sites while I am the most experienced and knowledgeable programmer at my site I often find my self in a debate with another site that has many programmers. They use legacy exclusively where I tend to use Xact.
What I have found is that in most cases the issue in which scheme is used is understanding what Xact does and further understanding the intent of the design. The main issue I hear from other programmers is they don't trust Xact especially if the FCF doesn't constrain all 6 DOF's and the datum shift shows up on the reports. After extensive testing and back and for between Hexagon and GD&T experts I have come to two conclusions.
1. Either the designer didn't properly constrain all 6 DOF's due to lack of understanding of GD&T or that was the original intent.
2. if you use legacy and the intent was to not constrain all 6 DOF's you are not reporting the correct information. Since legacy is based off of the alignment which locks all 6 DOF's.
So what happens is a lengthy back and forth about who is right and if the part is good or not. There is another underlying issue based on which version of the PC-Dmis we are "allowed" to use by company standard. I really don't think in this case version is an issue. I post this because while most of the post regarding legacy vs exact are many years old I would like to get the opinions of the forum on this. If needed I can go into more detail.
TIA
TIA
