I have two separate models that I need to joint together. After I import them, how do I translate/rotate each of them individually and then connect them?
Cad model transformation
Utilize the CAD ASSEMBLY dialog that you can access a few places, one which is via the Main toolbar using Edit | Graphic Display Window | CAD Assembly. Once the dialog box is opened, locate the assembly name in the tree (white space on left side of dialog box). CAD Assembly dialog box.PNG If you can only see the assembly name in the tree, left click on the 'plus' sign to the left of the name and the child components will show. You can then right click a component of the assembly in the tree and choose Transform. You can then utilize the CAD Transform dialog box to join them together as needed.
- 1 like
by Chally72I pulled this from a previous post of mine and added a bit to it.
The following is all done through the transform window in the graphics...-
Channel: Tips & Tricks
12-16-2009, 07:08 AM -
by UnderspecI now have two CAD models in graphics window. What's going wrong?
07-12-2007, 02:42 PM -
by ErikirIn most of my programs I create and import models for the part and all fixtures as well (Vices, TECO clamps, custom fixtures, etc.)
In some reports...-
01-23-2014, 12:00 PM -
I have an existing program with CAD file which required using the transform function to adjust the origin & axis. I now have a new revised Iges file...
03-24-2015, 02:36 PM -
by TomverHi all :
My 1st time to work with CAD model. I receive an .iges file from
our engineering but the model looks like a wire frame...-
11-25-2009, 06:50 PM -
