saving report pdf file in it path automaticlly
  • saving report pdf file in it path automaticlly
    hello guys
    we have just loaded our programs into new pc everything works fine except that when the measuring is done the "do you want to save pdf files" pop us and i select yes but instead of going to it default path (a folder named RC next to the programme folder) it gives the directory browse window to select where the file to be saved , what shoud i change in the code to have them saved wihtin RC path automaticlly
    ps: its pc dmis 2017r1
    tnx
    You need to change the file path. When you first open PC-DMIS, you should be able to select edit and then you can change the file paths in the directory.
    Darroll
    2018R2
      but every program has it RC path , its not a single path , its RC of every program folder , so cant select one , + a teammate that left had fixed this just from the code i just didnt know what he did and cannot even get in touch with him
      • Martijn
        Martijn commented
        Check directory and path where it's want to write to and make sure the structure is exactly the same on the new pc.
      new pc, new user, do you have setup access rights by IT guys (read&write) for the folder ?
        It's probably your (lack of) access rights to Computer\HKEY_CURRENT_CONFIG\Software\PC-DMIS 50 Converter - the PDF driver wants to store the path there, and pops up the dialog if it's not allowed to.
